1 to 4 shift
Old Dec 21, 2011 | 01:24 AM
Beach Lover's Avatar
Beach Lover
5th Gear
Default 1 to 4 shift
What is the purpose of this? When I'm in 1st and the rpm's get close to 1500, the 1 to 4 shift light comes on and it doesn't want to shift into 2nd. I have to either let off the gas or manhandle it into 2nd. Any way to avoid this other than shifting at 1200 rpm's?
Old Dec 21, 2011 | 06:45 AM
fastyellowss's Avatar
fastyellowss
you can buy a skip shift eliminator. I know their are forum vendors that sell them. You can also buy a hand held tuner to eliminate this. And lastly, you can have the car professionally tuned and they can eliminate this for you.
Old Dec 21, 2011 | 07:07 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
To the OP, the intent of this wonderful device, was it allowed GM to avoid a gas-guzzler tax on the Corvette. Shifting to 4th so quickly gets you into a more economical mode of operation....provided you don't get "rear ended" while looking for fourth gear, as it's not a "natural" shift from 1st.....
Old Dec 21, 2011 | 08:07 AM
vettenuts's Avatar
vettenuts
Also, don't force it into second. I have an LG skip shift eliminator if you are interested just send me a PM.
Old Dec 21, 2011 | 09:42 AM
dougbfresh's Avatar
dougbfresh
Read the owners manual-it's EXPLAINED!
Old Dec 21, 2011 | 12:34 PM
oh1vette's Avatar
oh1vette
Can also be tuned out...
Old Dec 21, 2011 | 12:46 PM
cdkcorvette7's Avatar
cdkcorvette7
As others have said it's called Computer Aided Gear Selection (CAGS) and it's explained in your owners manual. If you don't have an owners manual you can download one for free from GM Parts House. Essentially it's a solenoid that engages at certain RPMs while accelerating from first that prevents you from shifting into second.
You basically have two options if you don't like it (as many including myself do not).
Option 1: Install a hardware CAGS bypass available cheap from many forum vendors (also looks like someone who posted above has one available). With the bypass the 1 - 4 shift light will still illuminate but the solenoid will not engage and you'll be able to shift into second. The install is simple and takes no more than fifteen minutes taking your time. You simply unplug a wiring harness from your transmission at the rear of the car and plug the CAGS bypass into it then zip tie the hanging wire out of the way.
Option 2: Tune the CAGS out of the PCM via your own turning software such as HP Tuners or have a tuner do it for you. With this option the solenoid will not engage and the 1 - 4 shift light will not illuminate.
Old Dec 21, 2011 | 04:17 PM
_zebra's Avatar
_zebra
i just shifted to 3rd before mine was tuned out
Old Dec 22, 2011 | 12:54 AM
Beach Lover
5th Gear
Thanks for the info. I'll look into the options you've suggested. By the way, to a certain responder, I've found that the replies on here from other owners have been more helpful than the manual. Isn't that the whole point in having this forum? I greatly appreciate the help the rest of you were willing to take the time to offer.
Old Dec 22, 2011 | 01:59 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LMAO,,,,,,,,,,,,,,,,,,,,,,, Theres a THIRD option... BE a little more agressive on the throtte and you will never see it!
Old Dec 22, 2011 | 04:11 AM
ZeeOSix's Avatar
ZeeOSix
Shift above 2000 RPM when the 1->4 shift light goes out.
From Owner's Manual:
"Do not try to force the shift lever into SECOND (2)
or THIRD (3) when the 1 TO 4 SHIFT light
comes on. Do not try to re-engage FIRST (1)
after starting to shift into FOURTH (4). You will
damage your transmission. Shift only from
FIRST (1) to FOURTH (4) when the light
comes on."
This light will come on when:
  • The engine coolant temperature is higher than 169 F (76 C),
  • You are going 15 to 19 mph (24 to 31 km/h) and
  • You are at 21 percent throttle or less.
Putting a skip shift eliminator is what most guys do, then you don't have to be conscious all the time about your 1st to 2nd gear shifts to try and avoid the 1 to 4 skip shift.
Old Dec 22, 2011 | 05:54 AM
Oldvetter's Avatar
Oldvetter
The skip shift eliminator was the first and best mod to my car. No more almost getting rear ended when pulling away from stoplights while turning !
Old Dec 22, 2011 | 08:12 AM
leadfoot4's Avatar
leadfoot4
The first coule of times I was in traffic, I almost got rear-ended a couple of times. When you start to accelerate from a traffic light, the cars behind you generally assume that you'll be going at a uniform rate. They don't expect a spurt of acceleration, followed by a couple second slow down, while you search for 4th gear!!
To 1 to 4 shift
