Pinpointing annoying noise?
Old Dec 22, 2011 | 07:44 PM
GoBallsDeep!'s Avatar
GoBallsDeep!
Default Pinpointing annoying noise?
I have a noise that seems to be coming from below my car. At first I thought it was a bad cat rattling. Now using the hose trick to pinpoint the noise, it seems to be coming from the access hole at the end of the torque tube near the engine. After pulling the hole plug, its louder in there. Anyone have any input on this? Any help is appreciated. I'm starting to get really frustrated with the whole thing. I'm not really sure what I'm looking at inside the rubber plug..flywheel/flexplate? Is this balanced with weights? Thanks all!
Old Dec 22, 2011 | 07:48 PM
31coupe's Avatar
31coupe
By chance did you read my post about 5 down "Oxygen Sensors" you and I may have the same noise.
Old Dec 22, 2011 | 07:57 PM
31coupe's Avatar
31coupe
No codes as they are working fine just the rattle.
Old Dec 23, 2011 | 11:01 AM
31coupe's Avatar
31coupe
This is one of the suggestions that I got, plus a person you can get those sensors on ebay for 30.00 if that is your problem too.
http://www.permatex.com/products/aut...one_Gasket.htm
Old Dec 23, 2011 | 11:34 AM
corvettebob1's Avatar
corvettebob1
If you have an A4 you may have a broken flex plate you need to get a good look in there to see if it's broken.
Old Dec 25, 2011 | 04:43 PM
GoBallsDeep!
Checked the flexplate today. No cracks and all the bolts were tight. I did see a couple "scuffs" in the bellhousing area...
Sorry, with the lighting this is the best pics I could take. Could it be something with the starter?
Old Dec 25, 2011 | 08:04 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Sounds like the propeller shaft hub clamp needs adjusting. It needs to be loosened, and then;
Start and run the engine at idle until normal operating temperatures are reached.
Idle or drive for at least 10 minutes.
Turn off the engine and allow the powertrain to cool to ROOM temperature.
Raise the vehicle.
Tighten the propeller shaft hub clamp bolt to 125 N·m (93 lb ft)
You can find the details in the service manual.
Old Dec 25, 2011 | 08:10 PM
GoBallsDeep!
^Really? Is this the allen key clamp bolt? Thanks E!
Old Dec 25, 2011 | 08:17 PM
Eric D's Avatar
Eric D
Old Dec 25, 2011 | 08:25 PM
GoBallsDeep!
Yeah, that's it!
Old Dec 25, 2011 | 08:36 PM
GoBallsDeep!
Thank you Eric, but what do you think the manual means by loosen? I would think loosening it too much, it would just slip? I appreciate your help!
Raise the vehicle.
Old Dec 25, 2011 | 09:02 PM
Eric D's Avatar
Eric D
It has a spline, so no it won't slip in rotation, but it will move fore/aft as it grows from thermo expansion. This manual step sets it to a neutral point so that it doesn't put load on the flex plate. The noise it makes is like a rattle when not adjusted properly.
Old Dec 25, 2011 | 09:10 PM
Dixiecrat's Avatar
Dixiecrat
Good Lord is there anything you guys dont know lol ?
Old Dec 31, 2011 | 02:08 PM
GoBallsDeep!
I did this procedure twice and it seems to make a worse rattle. Anyone have any ideas? Thanks
Raise the vehicle.
Old Dec 31, 2011 | 04:10 PM
Eric D's Avatar
Eric D
See PM.
Old Dec 31, 2011 | 04:45 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
can you make the noise change from P to N to D(brake on)?
Sounds like your on the right track, I've never seen an A4 making the noise you have there, my dad had a '98 with over 220,000 miles, never did that
let us know what you find
Old Dec 31, 2011 | 04:53 PM
GoBallsDeep!
^no, I have the noise P/N/Red light w/ foot on brake. Any thing over say 1k rpm its gone. It's more prominent now in P and N after "adjusting the propeller shaft hub clamp". Thanks
To Pinpointing annoying noise?
Old Jan 1, 2012 | 06:49 PM
GoBallsDeep!
Anyone have any suggestions?
Old Jan 1, 2012 | 07:50 PM
Willby70's Avatar
Willby70
Check all engine and trans mounts. Seems when you increase rpm, the resulting torque is removing the nosie. So, get car up safety/secure and run see if you can see the driveline flex. Next would be the torque tube.
Old Jan 1, 2012 | 09:40 PM
Eric D's Avatar
Eric D
The issue has nothing to do with "resulting torque". It is a resonant issue. Engine pulsation in the right frequency range will light-off the resonance. The resonance has to do with the transdiff and part of the reason all C5's have a 58Hz tuned absorber mounted on the left diff side cover. Peek resonant point is 870 rpm.
