headers or cam??
Old Dec 25, 2011 | 09:01 PM
04blackice's Avatar
04blackice
Default headers or cam??
04 z 75000 miles. Whats best bang for me buck.checked on ar headers.what will a cam job run me
Old Dec 25, 2011 | 10:09 PM
SR-71's Avatar
SR-71
Headers with a tune will give you a nice bump in power, add an intake(vararam) to really optimize your stock stuff. Then get yourself a cam kit to top it off down the road. Check out the cam kits the site sponsors have; Vengence, Texas speed, and LG motorsports are all good places to start. I gave 650 for install and dyno tune for my cam kit, but prices will vary.
Old Dec 25, 2011 | 10:29 PM
jrose7004's Avatar
jrose7004
I'd go for the headers.
Old Dec 25, 2011 | 10:58 PM
BOUT X's Avatar
BOUT X
Corvette Cowboy
the thing thats sucks is you live in Ca. so it's a hard choice
1,000 % and get the LG's longtubes it was my first up-grade and it will give you a sweet sounding car and give you some punch remember you will need a tune also and that will run you 400.00 to 500.00 and since you are in the LA area check out RPM Motorsports in Santa Clarita, Charlie Williams is a good guy and good shop. Then spend some time and figure out what you want to do as for living in Cali your best option is to go FI as you can get that smogged in Ca. if you build a cammed motor you will have a hard time every 2 yrs.
Old Dec 25, 2011 | 11:09 PM
m6 c5's Avatar
m6 c5
Wont he fail visual with headers?
Old Dec 26, 2011 | 08:32 AM
BOUT X's Avatar
BOUT X
Corvette Cowboy
Yes he can but, their are more shops that will over look them if it will pass the sniffer
Old Dec 26, 2011 | 08:37 AM
AU N EGL's Avatar
AU N EGL
You live in CA ??
dont think LTs will pass. Shorties might.
a smallish cam 224/228 581/588 114 or 113 new springs, new push rods, a good tune and you will still pass the smog police.
Old Dec 26, 2011 | 09:05 AM
mitchcole's Avatar
mitchcole
Originally Posted by AU N EGL
You live in CA ??
That smallish cam will make great power. If it's truely an either/or situation - go with the cam. I did the cam, intake, heads, headers ended up with 412 at the wheels. You already have the intake and heads that I used. my cam is even smaller at 222/226 @ 600 lift and 115 LSA. It ran poorly till the tune. look me up and see the thread.
Old Dec 26, 2011 | 07:31 PM
04blackice's Avatar
04blackice
Yes in cali dammit.but there is always tricks in the trade.anyways looks like more header votes.. looongtubes..thanks everyone
Old Dec 26, 2011 | 09:00 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Vote out the Libs out there in CA. Then do hearders AND a cam with a tune!
You could move to a real state, like mine!
Seriously, headers where you live is your best bet.
Old Dec 27, 2011 | 06:14 AM
04blackice's Avatar
04blackice
Yep.cali sucks ***.do this do that.ohh cant do that or that.aome day ill get out of this dump
Old Dec 30, 2011 | 02:30 AM
BOUT X's Avatar
BOUT X
Corvette Cowboy
I live only 60 min. away from a area that doesnt require smog checks every 2 yrs in Cali. and the more I think about it the more I am willing to drive farther for work
Old Dec 30, 2011 | 06:46 AM
04blackice's Avatar
04blackice
Lucky you..where abouts is that??
Old Dec 30, 2011 | 08:34 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
Both are a waste of money unless you are willing to do the work yourself, especially in CA. Long tube headers are not CARB legal, and HF cats will most likely not pass the exhaust gas analyzer test.
Your best bet is to opt for a small cam with little or no overlap and leave the exhaust system intact.
Old Dec 30, 2011 | 09:35 AM
TXGS507's Avatar
TXGS507
Great advise here... Cam, No headers... WOW!
Old Dec 30, 2011 | 10:45 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Originally Posted by 0H1Z06
Great advice here...Cam, No headers...
Not trying to picks sides, but he's right. Unless you feel like swapping in factory/shorty exhaust and h-pipe back in every year... longtubes don't make sense.
There's plenty of baby cams that can make 30+ hp on the stock manifolds and pass smog.
If I was in Cali.... I'd move away from there, but if I had to stay I'd honesly just save for a 50-state supercharger...
Old Dec 30, 2011 | 11:50 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
You obviously have no idea how a header works.
To headers or cam??
Old Dec 30, 2011 | 01:12 PM
jimlikeschevys's Avatar
jimlikeschevys
You guys might want to ask the OP what kind of emissions test he has in his state. Many states only plug into the OBD2 port and if your monitors are good, and you have no check engine light, you pass. There is no sniffer test anymore. So, you can go for long tubes, drop your cats, or go with high flow cats, and tune out the rear 02 sensor and pass emissions all day long.
Headers are the way to go IMO, you pick up some HP without getting inside your engine and risk fracking things up. However if you've got an **** emissions process, then cam might be your only alternative unless you wanted to change out the rear end ratio with a new set of gears.
Old Dec 30, 2011 | 04:40 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
There is no need to ask on my part, I was stationed in CA for several years, CA performs a sniffer test along with plugging into the OBD port. I owned two C-5s while I was out there. The 2001 coupe had a small custom ground cam and a set of 243 heads that I installed while I was there. The exhaust system was stock, the car ran very well and was smog legal.
Old Jan 2, 2012 | 01:16 AM
BOUT X's Avatar
BOUT X
Corvette Cowboy
Mariposa county just outside of yosomite about 40 miles all you do is smog it when you enter then just pay the tags after also Lake County which I have 10 acre's of land is smog friendly
