coilovers on rear only
Old Dec 26, 2011 | 05:57 PM
geogolf's Avatar
geogolf
Default coilovers on rear only
can you do just coilovers on rear, thought about trying it to control some of the wheel hop problem tia for replys geo.
Old Dec 27, 2011 | 07:41 AM
geogolf's Avatar
geogolf
Default coilovers
ttt
Old Dec 27, 2011 | 07:43 AM
AU N EGL's Avatar
AU N EGL
Not a good idea
Wheel hop, check your tires age.
Try dropping the air pressure in the rear tires.
and what tires are you running? older tires with smallist side walls will hop
Newer sticky tires with tall sidewalls should not hop as much
Old Dec 27, 2011 | 07:55 AM
geogolf's Avatar
geogolf
Default hop
thanks for the reply, did not know if you could do just the back or not some on here said coilovers do help with hop but I am sure they did frt and rear. my tires are low profile and I know that is part of prob. geo.
To coilovers on rear only
