Clutch Hyd Line coupling
Old Dec 27, 2011 | 09:41 AM
k24556's Avatar
k24556
Default Clutch Hyd Line coupling
The service manual says: "using the J 36221 depress the white circular ring......." Well I tried that no luck, tried every other suggestion on the forum site. I finally got it loose with a tool my dad had in his tools.
This is a small engine valve spring compressor tool.
Adjust the fingers on the white circualr ring end to just cover the ring, not the gold colored connector which has to come out. Adjust the fingers on the other end to contact the back of the female part of the coupling. Then just a little pressure from the compression screw.. not much. Wiggle the coupling a bit and poof, apart!
Old Dec 27, 2011 | 10:17 AM
striper's Avatar
striper
I have the correct type of tool and it still was a pain to get apart. Not much room to use your hands.
Old Dec 27, 2011 | 10:59 AM
johnson-rod's Avatar
johnson-rod
I used a modified 1958 Chrysler interior door and window handle remover tool and I had to grind it out to the correct size opening.
Damn. Now it probably doesn't fit 1958 Chryslers anymore.
A shot of WD-40 helps too.
Old Dec 27, 2011 | 11:13 AM
Its_Go_Time's Avatar
Its_Go_Time
I made this thing...basically a really flat 5/8 wrench. Works like a charm every time!
Old Dec 27, 2011 | 11:38 AM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
^^^ that is the way to do it. Those cheap stamped wrenchs you get w/ air grinders also work very nice for that job.
I can't imagine trying to wrestle that big contraption in the first post to unhook the line.
Old Dec 27, 2011 | 11:54 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Maybe I've got this wrong, but I thought the tool shown in the first post is for aiding in snapping the disconnect together.
Old Dec 27, 2011 | 02:44 PM
johnson-rod
No tools are necessary to snap it together.
Perhaps they should have called it a 'quick connect' fitting.
Old Jun 6, 2014 | 08:21 AM
vettenuts's Avatar
vettenuts
I tried everything (two days worth) and finally with two small screwdrivers popped it apart in a couple of minutes. I like the small engine valve spring compressor idea, have to remember that if there is ever a "next time".
To Clutch Hyd Line coupling
