So after getting it all back together and not having any pressure i pulled it all apart again to find the oring pinched. After getting it back together with the proper oring my cold pressure is much better.. 70* 65psi, but hot pressure is still low 200* 14psi.
What is the pressure at a new cold start? Are you using the same oil filter or did you change it?
Unless I missed something, I don't see where you verified the oil pressure with a mechanical gauge.
Knowing that the motor was built with "loose" clearances, and not knowing how loose, you may just be chasing your tail.
I have not yet done this, but I have replaced the sender with a brand new one, and still have the same readings. I know i need to get ahold of a mechanical gauge and test the pressure, im going to try and get one tomorrow
None yet, Ive been slammed with work and havent had the time to or energy to work on the car. Im going check the cam retainer plate next to make sure it is fully tightened and has a good seal
