Oil pressure questions
Old Dec 29, 2011 | 07:46 PM
xDIRTYx's Avatar
xDIRTYx
Default Oil pressure questions
My oil pressure seems to be low, im pretty sure a new pump will fix it but i just want to get a couple more opinions. A quick background, forged 346 with "high tollerance" clearances, d1 procharger, ported ls6 pump, mobil1 15-50, ac delco pf46 filter. 65* oil temp shows pressure around 45psi and 200* oil temp shows 12psi at 850rpm idle. Driving around at about 2500rpm gets to about 30psi. What are your thoughts? Ive ordered a mellings hv hp pump but havent installed it yet, hoping this will fix it. The car hadnt run in 3-4 years before getting it all back together earlier this week
Old Dec 29, 2011 | 08:10 PM
Lothar34's Avatar
Lothar34
When you say "high tolerance" do you mean tight, or loose?
Even if it's loose, I've not seen any that run as low as 12psi hot idle, especially not with 15w50.
Old Dec 29, 2011 | 08:12 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Have you put a mechanical pressure gauge on it to see if the oil pressure is what you believe it is? This should be your first step.
Old Dec 29, 2011 | 08:24 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
12psi at 850 RPM idle is definitely a problem.
Lets break this down.
Ported LS6 oil pump... Check
Mobil 15W50 oil... Check
Oil Temperature 200*... Check
AC Delco PF46 oil filter... Check
Forged 346.... How long ago did you have the forged motor built, and have you always experienced low oil pressure when the engine is hot?
The car hasn't been run in 3 to 4 years... "Got it all back together earlier this week".
What does that mean? What was assembled earlier this week and what is its connection to the oil system?
I'm not convinced that a Mellings High Volume HP Pump will resolve the low oil pressure issue.. yet.
Crazy question, did you check your oil level? Are there any oil leaks?
Was this the same oil and filter that's been sitting in the car for the past 3 to 4 years? or did you do an oil change?
Old Dec 29, 2011 | 08:48 PM
xDIRTYx's Avatar
xDIRTYx
sorry i meant loose, although i do not know how loose it is.
I have not yet done this mainly because the gauge seems to be consistent and not irratic.
The motor was built approx 6 years ago, and has maybe 8k miles on it. I recently bought the car and am not 100% sure it has always been low. I have known of this car for many years though and although the previous owner does not recall low pressures I think this may have been a gradual problem.
Sorry for the vague description, but it was torn down for new head gaskets years ago and only got the heads back on before it sat. I reinstalled basically all the bolt ons with the short block being untouched since the build.
I have changed all the fluids in the car. Actually changed the oil twice because the first time i used 5w30 and was only seeing 9psi hot @ idle, so i dumped that oil and replaced it with the 15w50. I have tripple checked the oil
Old Dec 29, 2011 | 08:56 PM
xDIRTYx's Avatar
xDIRTYx
Here is my thinking... Either the relief spring in the pump has weakened/stuck from sitting for so long, the oil pick up may be somewhat blocked or restricted, or there is something else going on. Maybe the bearings are pounded out? Im really just taking a shot in the dark with replacing the pump thinking this is the most viable option
Old Dec 29, 2011 | 08:57 PM
Gray Ghost GS
I would definitely use a mechanical pressure gauge and contact the engine builder to see if he has any recommendations. I don't know how well you knew the previous owner, but when you say, "I recently bought the car and am not 100% sure it has always been low." it makes you wonder if he sold the car because he knew it had a low oil pressure problem for some unknown reason. I don't want to sound pessimistic..but.
Old Dec 29, 2011 | 09:08 PM
xDIRTYx's Avatar
xDIRTYx
The problem with trying to contact the builder is that it was done so long ago. I dont like your thinging but im goning to have to agree Ill get a mechanical gauge on it possibly tomorrow before i tear it down for the new pump. I have a feeling the bearings have seen their better days and am hoping the HV of the new pump will prolong the life of the bottom end
Old Dec 29, 2011 | 09:25 PM
ZeeOSix's Avatar
ZeeOSix
What kind of oil pressure do you see with oil at 200 deg F and RPM held at 5000 until the pressure stabilizes?
If it gets up towards 70 psi, then the oil pump's pressure relief valve is working correctly and the low oil pressure at lower RPM is probably due to loose clearances in the motor.
Old Dec 29, 2011 | 09:27 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Could be as simple as a bad o-ring seal on the existing oil pump. It happens,,,
Old Dec 29, 2011 | 09:34 PM
Eric D's Avatar
Eric D
Things that can cause low oil pressure:
Stuck oil pressure relief.
Bad oil filter.
Blocked pickup tube screen.
Bad, pinched o'ring at the pickup tube to oil pump.
Bad oil pump.
Low oil level.
Bad oil pressure sending unit.
When oil pressure is low the valvetrain will make noise.
Old Dec 29, 2011 | 09:37 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Bad oil filter.
Bad oil pump.
Low oil level.
this can also cause low oil pressure like the OP described.....car never made a noise and ran fine....
it was mushroomed in the head...had to pull the cam to remove the lifter
Old Dec 29, 2011 | 09:53 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
Old Dec 29, 2011 | 10:29 PM
Eric D's Avatar
Eric D
Attachment 47687478
Attachment 47687479
Attachment 47687480
You maybe correct that it didn't make any noise to an untrained ear, but I can assure it does make a noise. Even with as bad as your lifter roller looks, it typically does not change indicated oil pressure.
Old Dec 30, 2011 | 01:38 AM
xDIRTYx's Avatar
xDIRTYx
Im not sure, ive only had it up that high in rpm a few times and i was watching the road. The low idle pressure has me scared to just rev it and hold it up there like that.
Could be but if i do all the work to get to the o ring, im putting in a new pump just because
Bad oil filter.
Bad oil pump.
Low oil level.
I dont really hear too much valvetrain noise at the 12-14psi its at now, but it would be somewhat hard to hear over the exhaust and blower noise. Im just going to go ahead and replace the pump, o ring, and check the pickup this weekend. Your post got me to thinking maybe the o ring rotted? seeing as it was used then parked for about 3 years...
Attachment 47687478
Attachment 47687479
Attachment 47687480
I would assume you would be down 1 cylinder and mine is deffanetly running on all 8. Hard to imagine that didnt make any noise at all
Old Jan 2, 2012 | 09:28 PM
xDIRTYx's Avatar
xDIRTYx
a quick update.. I pulled the oil pump out to find out it had a melling m295 pump in it with a couple small washers as shims. Everything looked ok with the pump but the pressure relief piston moved ok towards the top of the bore, but when trying to remove it it would get stuck toward the bottom of the bore. It took a good amount of force to get it unstuck and out. Im going to go ahead and install the HV HP melling pump and report back
Old Jan 2, 2012 | 10:16 PM
Lothar34's Avatar
Lothar34
Why the shims? Do you have a double roller? My double roller set came with shims but they were not washers. They were machined and cut for the mounting locations and the oil pathway.
To Oil pressure questions
Old Jan 3, 2012 | 12:16 AM
RonSSNova's Avatar
RonSSNova
I believe he means washers as shims for the pressure releif spring.
Old Jan 3, 2012 | 07:43 PM
USA-1 HP's Avatar
USA-1 HP
Does the oil pan need to be unbolted at all for the pump replacement?
Old Jan 3, 2012 | 07:48 PM
pewter99's Avatar
pewter99
the chunks were making oil flow less than optimum at idle...
I swear you would have never known that lifter was toast.... not any indication at all....until oil pressure went to 0 THEN
on steering wheel
