stock ls1 cam recommendations??
Old Jan 8, 2012 | 06:23 PM
97AutoXVette's Avatar
97AutoXVette
Default stock ls1 cam recommendations??
Hey Guys,
Looking to put a cam into my otherwise stock LS1. going to put in the LS2 intake manifold and 90mm TB as well.. Need some recommendations for what cam is best?
Still want it to be streetable but want something that will help me more in the drag race scene and for open tracking the car.
Thanks in advance
Old Jan 8, 2012 | 06:31 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
A4 or MN6?
Old Jan 8, 2012 | 06:33 PM
97AutoXVette
Originally Posted by silverbullet00
a4 or mn6?
mn6
Old Jan 8, 2012 | 06:47 PM
Silverbullet00
Originally Posted by 97AutoXVette
mn6
I am running a cam with the following specs:
228 230, 581, 585 113 LSA Comp Cam with hardened 7.4 push rods and Patriot Gold springs.
Other engine mods:
VRB2 Air intake
Dynatec Supermaxx LT headers/ HF cats
Corsa Catback
160 Thermostat
Dyno Tune - conservative/safe tune on 91 Octane
My car is also a MN6 with stock clutch.
Car dyno numbers 365 RWHP, 374 RWTQ.
With the VRB2 effect above 50-60 MPH the car is nearing 400/400.
I wouldn't want anymore lift or LSA than my setup. My car is very streetable but you never forget about the cam. Nice lope and a gentle shake at idle.
I plan to upgrade the heads and intake manifold but I am in no hurry.
Hope this helps!
Old Jan 8, 2012 | 06:56 PM
Paul 75 L82's Avatar
Paul 75 L82
Check out Texas Speed 228R.
Old Jan 8, 2012 | 07:14 PM
97AutoXVette
Other engine mods:
VRB2 Air intake
Corsa Catback
160 Thermostat
Hope this helps!
Absolutely! Thanks a ton.. I also have an intake, full exhaust w/ long tubes, and a 160 Tstat. looks like I will be lookin into a cam along these lines.
Old Jan 8, 2012 | 07:15 PM
97AutoXVette
Will do.. Appreciate it.
Old Jan 8, 2012 | 08:02 PM
AU N EGL's Avatar
AU N EGL
241 heads? is so the 241s dont flow much above 550 cam lift
243 heads flow well to 575-580 valve lift
Old Jan 8, 2012 | 08:45 PM
97AutoXVette
Good point. 241 heads currently but I will likely be upgrading to 243 heads in the future at the very least. Will most likely end up buying a set up aftermarkets (hopefully some used AFRs) down the road.. think it would be best to have the 241s ported/polished vs. aftermarkets from a cost/benefit standpoint??
Old Jan 8, 2012 | 08:52 PM
vettenuts's Avatar
vettenuts
I would look at the LS6 intake (all later years had this) rather than the LS2. It flows better.
Old Jan 8, 2012 | 09:16 PM
AU N EGL's Avatar
AU N EGL
Dont do a cam until you can do the heads and timing chain at the same time
Old Jan 8, 2012 | 09:46 PM
97AutoXVette
Yessir, agreed. Have seen plenty of dynos showing how well the LS6 manifold compares to the other LS-series intakes.
Old Jan 8, 2012 | 09:47 PM
97AutoXVette
Have the LS2 timing chain ready to go in with the cam swap. Do you know if I can do the cam/timing chain swap without dropping the oil pan? heard something about having the drop the oil pan or move the oil pump, etc. but not sure on the accuracy of that? Thanks!
Old Jan 8, 2012 | 10:21 PM
sfc rick's Avatar
sfc rick
Old Jan 9, 2012 | 10:51 AM
nullpointer's Avatar
nullpointer
I just did a cam swap on a 02 z and I didn't have to touch the oil pan.
Old Jan 9, 2012 | 10:52 PM
A.R. Shale Targa's Avatar
A.R. Shale Targa
Check out the EPS 226/230...very streetable manners and a slight bump
at idle just to warn the 5.0 fellas what's commin'
To stock ls1 cam recommendations??
