Leaving Headlights up manually?
Old Jan 15, 2012 | 08:17 PM
David Shiel's Avatar
David Shiel
Default Leaving Headlights up manually?
If I open the headlights manually and leave them up, will it cause any problems with the motors or controls? I just like the look. Used to have a '71 and had an override so I could leave the light s up at will. If traveling at speed would likely manually retract them.
Old Jan 15, 2012 | 09:42 PM
jcgunn's Avatar
jcgunn
The problem is...as soon as you turn the lights OFF they will retract.
Old Jan 15, 2012 | 10:25 PM
don hall's Avatar
don hall
From Corvette Forum search:
"If you turn on the headlights, then go to parking light position, the lamps remain up but the headlights are not left on."
Old Jan 15, 2012 | 10:31 PM
Lothar34's Avatar
Lothar34
Yeah they will close when you turn them off.
If you like the look then you can raise them and disconnect the motors.
Old Jan 15, 2012 | 10:34 PM
don hall's Avatar
don hall
Originally Posted by Lothar34
Yeah they will close when you turn them off...........
Not if you turn to the parking lamp position...........
Old Jan 16, 2012 | 03:34 AM
DeeGee's Avatar
DeeGee
Select On and back off to park. You could pull the headlamp motor fuses (3&4 under hood) but this is the easiest way.
Old Jan 16, 2012 | 03:57 AM
Lothar34's Avatar
Lothar34
But then he'd have to keep doing that every day after he turned the parking lights off.
Old Jan 16, 2012 | 07:21 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
When I see a car driving down the road in the day with the lamps up (not necessarily a Corvette), the first thing I think is the person is too lazy to figure out what's wrong with them and fix it. Looks ridiculous too me but the OP didn't state why he wishes to do this. Maybe he's got a good reason. Now what does look cool in the day time is running with the fogs on but again, there you need to turn on the parking lamps, keeping the headlamps down.
To Leaving Headlights up manually?
