A4 Transmission, NEED HELP!!!
if you don't like what the subject is, give the rest of us a break and don't post. He's entitled to ask a question, everyone else is entitled NOT to comment if they don't like the question. Last I heard this forum is still part of the USA.
Good luck
Mike V
God, some people on here need a ****ing beer or something....
Good luck.
Mike V
You can do an impromptu vacuum test by closing off the bottom intake of the filter with your hand and sucking on the discharge tube part of the filter that plugs into the transmission.
Thanks to those who chimed in!! It might be a while, but Ill let yall know what happens....Maybe Ill do a good right up on pulling the transmission with Pic by Pic steps
Just to clear things up: The car was not only being pulled apart because of transmission issues, but for a torque converter swap too!! The transmission issue just gives me a reason to do it sooner. Everything was gonna come out sooner or later anyways. Plus, like stated before, with over 105k miles, now is not a bad time to get it all rebuilt.
Here is a link to some of the photos I took during the whole process.
http://www.flickr.com/photos/75484736@N04/
Thanks for the photos. Is there a particular reason you removed the torque tube? Once done with my H/C/I/H mods, the trans faces me next. Also for a converter. But also to upgrade to a later beefed trans and a 3.42 diff.
And, like you, I will be doing this on the garage floor. Oh boy.
Ron
Ron
