Harland Sharp rocker install ?
Old Jan 27, 2012 | 11:19 PM
a/c man's Avatar
a/c man
Default Harland Sharp rocker install ?
Ok I changed my stock rockers out for some harland sharps because they say with AFRs the guides are bronze and will wear out with stockers
it seems to have more valve train noise is this just the way they are? I checked my preload and its about the same as the stock ones
thanks for any info! I did a search and found nothing on the characteristic of the rockers
Old Jan 28, 2012 | 01:07 PM
corvettebob1's Avatar
corvettebob1
Yes, they will have more noise then the stock rockers, it's because they are aluminum and by it's nature aluminum has 0 sound dampening properties.
Old Jan 28, 2012 | 05:17 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Who is they and how does the HS rocker arm reduce side loading on the valve stems? The only valve train component you replaced was the rocker arms and you have increased valve train noise?
Old Jan 28, 2012 | 05:23 PM
a/c man's Avatar
a/c man
yes just rockers
Old Jan 29, 2012 | 01:34 PM
corvettebob1
"They" would be any head mfg. that uses bronze wall guides. The sliding effect of the stock rocker will side load the guides causing excessive wear.
AFAIK, All of them recommend using full roller rockers to eliminate the problem.
Old Jan 30, 2012 | 05:30 AM
vettenuts's Avatar
vettenuts
Before installation, did you set the geometry (wipe) of the rockers or just bolt them in? If the geometry is off, the result could be more side loading which then defeats the intent of using them.
To Harland Sharp rocker install ?
