Has anyone that has had to replace connectors and harnesses ever used crimped & heat shrinked butt splices? And have those butt splices ever failed on you for any reason after that?
I originally used solder, and I suspect that my solder connections are getting compromised by heat, and I was wondering if there was a solid alternative to buying a Delphi Weather Pack connector rebuilding kit... because they are expensive and hard to find.
I think I would consider "inline" splices as apposed to "butt" splices with a heat shrink tube shrunk over the splice.
My experience is that this method makes a clean, neat job of splicing and protecting two spliced wires. You will also ends up with a smaller splice if you have multiple wires/splices.
This is not difficult to do. Just use the proper solder, flux and soldering iron/gun.
Yes, yes...I have always felt the same way...solder always the best option.
BUT... I have an oxygen sensor problem...and replacing the sensor didn't didn't solve anything. My o2 wiring was previously repaired with soldering.
Soldered connections in close proximity to exhaust headers doesn't seem to be a great idea anymore.
If you're worried about heat generated from the headers, I'm sure that any heat generated would not affect the soldered joint, and I doubt very much if you would see anything with the heat shrink tube either unless it touches the header.
Agreed. I can't see there being a problem with just ambient heat. If the wires are touching the exhaust pipe you are going to have problems solder or just wire.
You always want to use dual wall heat shrink tubing in an all weather location. The dual wall is thicker and has a glue on the inside that seals the joint.
A solder joint is weak where the solder ends at each wire. It can fail if it flexes there. Keep it from flexing and it will live a long life.
