power loss on 2003 corevette
Old Jan 28, 2012 | 07:06 PM
retlaw31jh's Avatar
retlaw31jh
1st Gear
Default power loss on 2003 corevette
We purchased new a 2003 corvette 50th anniversary convertible and in a few years had a power loss problem while driving. We do not drive it hard. The dealer could not find a problem and after about 2 years of this problem, replaced the fuel pump and the problem went away for a few years. This problem is back again. The car runs good around town; however, on a trip of over 120 miles there will be a loss of power so the car jerks with the cruise control on. When accelerating the engine wants to die but will run if you try and maintain minimum load on the engine.
Can anyone help with this problem?
Old Jan 28, 2012 | 07:17 PM
Jnape's Avatar
Jnape
Check your codes and post them up here. Do you know the procedure on your car to check codes?
Old Jan 28, 2012 | 07:23 PM
mchicia1's Avatar
mchicia1
Check the easy things first..
Fuel and spark at each cylinder. Could also be clogged cats.
Old Jan 28, 2012 | 10:35 PM
dougbfresh's Avatar
dougbfresh
AND, get a mechanical fuel pressure guage on it when it happens.
Old Jan 29, 2012 | 12:20 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
DTCs???????????????????????????????????? ???????????????????????
Please post!
Old Jan 29, 2012 | 01:11 PM
jsbzoh6's Avatar
jsbzoh6
Have you changed out the fuel filter recently? How many miles are on the car?
To power loss on 2003 corevette
