ABS/Traction Control
Old Jan 30, 2012 | 12:28 AM
Fun2Day's Avatar
Fun2Day
Default ABS/Traction Control
My ABS/Traction Control light stays on after starting the engine. I have had the connections cleaned and the grounds cleaned. I works better that before, but periodily (sp) it will stay on. I am being told I need a very expensive part and several hundred labor for a total of about $1,500.
I have 77K on a 2001 Roadster.
Any ideas before I spend the money on a new moduale?
Last edited by Fun2Day; Jan 30, 2012 at 12:29 AM. Reason: signature picture missing
Old Jan 30, 2012 | 02:26 PM
Fun2Day's Avatar
Fun2Day
Default codes found
Here are the codes I found.
10-pcm PO141C
28 TCS C1214H
60-TPC B0516H
80 Radio U1016H
99 HVAC B0338HC
AO-LDCM B2284H & U1064H
A1 RDCM U1064H
A6 SCM B2606H,B2860H,U1160H & U1064H
BO RFA U1000H & U1064H
I'll wait for your reply, thanks!!!
Old Jan 30, 2012 | 03:04 PM
dougbfresh's Avatar
dougbfresh
C1214 is your problem, www.absfixer.com can repair your EBCM.
Old Jan 30, 2012 | 03:39 PM
Fun2Day's Avatar
Fun2Day
Default Thank you
I have contacted ABS Fixer and will be sending it to them tomorrow. Based on comments from their web site, they should be able to fix it. They will give me a lifetime warrenty.
Thank you again.
wally
PS I am also having my mechanic look at these codes and see if they are causing any more problems. The car runs great and I have not really had any problems.
To ABS/Traction Control
