Catch can question?
Old Feb 1, 2012 | 11:04 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Default Catch can question?
I just installed my oil catch can 3 days ago on my 04 non z. It is about an 1/8 full. Is this normal?
I am worried that this amount has been like this for quite some time and could be effecting the internals more than I thought. Is there any steps I can take to clean up the damage done over the years?
Old Feb 1, 2012 | 11:43 PM
chad3113's Avatar
chad3113
You could give SeaFoam a try. I've used it on a few of my past cars. Its one of those "No measureable benefit, but won't hurt" type of things. Basically its supposed to clean out carbon/oil deposits within your engine.
Google Seafoam and you'll get a ton of info plus Youtube videos. It puts out a smoke show
Old Feb 2, 2012 | 01:03 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
Seafoam is good stuff. I would pull the intake and clean it
Old Feb 2, 2012 | 10:22 AM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
just spray the intake with simple green, rinse and repeat? any other tips for cleaning the intake?
thanks...and hopefully this isn't a hijack
Old Feb 2, 2012 | 02:51 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Hijack?.......
Old Feb 2, 2012 | 03:23 PM
bumble-z's Avatar
bumble-z
c5vette211, If you were doing some serious rpm's in those three days, & was driving hard, then it's not uncommon to have that much oil in your can.
As far as getting in there to clean any previous build up, I'd pull the intake as suggested & clean up any & all gunk.
Good luck.
Old Feb 2, 2012 | 03:45 PM
baxsom's Avatar
baxsom
the smoke show you see on the youtube videos of seafoam is because one of the main ingredients of seafoam is light oil.
Old Feb 2, 2012 | 09:47 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Thanks for the suggestions.... I am still curious about this Hijack though....
Old Feb 2, 2012 | 11:05 PM
95wht6spd's Avatar
95wht6spd
hijack, it just means that someone took the thread off topic. lol
Old Feb 2, 2012 | 11:30 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
yeah, I was hoping some one would answer my question but didnt want to change the topic
Old Feb 3, 2012 | 05:04 AM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
I see! Thanks!
Old Feb 3, 2012 | 07:26 PM
_zebra's Avatar
_zebra
if it makes you feel better, i just put my catch can on my Maggied car & took it for a test run. once i made sure it was routed right & not blowing backwards or anything, i gave it about a 10min run where the only time it dropped below 3k rpm was coming up to lights/stops. i gave it a cool-down & parked it. after everything cooled off, i checked the can & had almost enough to cover the bottom. that was just a 10min drive.
Old Feb 3, 2012 | 07:54 PM
sean.b's Avatar
sean.b
i'd be willing to bet with the way I drive, and the amount I constantly wash off my rear bumper, that I'll be right there with you!
I fully intend to do that ls6 galley/PVC swap when I do the head/cams. hoooopefully that helps. stupid thing eats a quart of oil, sometimes two, in between changes!
Old Feb 3, 2012 | 08:26 PM
_zebra's Avatar
_zebra
yeah, mine actually never used oil til i put the blower on.
Old Feb 3, 2012 | 08:28 PM
sean.b's Avatar
sean.b
mine did at a slower rate than after the headers, but i think that may be more correlation than causation.. i liked the way it sounded, therefore i was more motivated to drive harder
Old Feb 3, 2012 | 11:56 PM
printmanjackson
be sure to pull off the MAP sensor off before you wash it.
Old Mar 1, 2012 | 08:52 PM
skull's Avatar
skull
what is the ls6 galley/pvc swap?
Old Mar 1, 2012 | 08:53 PM
sean.b's Avatar
sean.b
http://ls1howto.com/index.php?article=18
Old Mar 1, 2012 | 10:36 PM
Dave68's Avatar
Dave68
By the way, the polycarbonate reservoir your catch can has is prone to cracking over time after being exposed to synthetic oil and residual gasolene from blowby. I just spoke to a Mustang owner who has a similar "can". He found oil leaking on his garage floor and traced it back to the crazed and cracked polycarbonate reservoir. Better alternatives are aluminum, zinc, and glass.
To Catch can question?
