check engine
Old Feb 4, 2012 | 08:55 AM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
Default check engine
hello everyone.
the check engine light came on a few months ago. I reset it and it come back on. the computer shows no codes anyware. I had some
trouble with the bridge on the varram a while ago. they sent me a new one and it fixed the problem. now I am not sure what it is. gas cap seems fine. does anyone have any advise? thanks Jim.
Old Feb 4, 2012 | 09:38 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
As suggested, pull your codes using the DIC. If the CEL is on, a code IS there.
Old Feb 4, 2012 | 09:52 AM
JBrooke825's Avatar
JBrooke825
I did that. I only get history codes nothing current. I"ll go do it again. thanks
Old Feb 4, 2012 | 10:14 AM
k0ts's Avatar
k0ts
You've got it... What codes did you get??
Old Feb 4, 2012 | 11:06 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Old Feb 4, 2012 | 12:18 PM
JBrooke825's Avatar
JBrooke825
Default Codes
here you go.
tried it again.
10-PCM-P0171 H
AO-LDCM-U1064 H
A1-RCDM-U1064 H
A6SCM-U1160-H
U1064-H
Old Feb 5, 2012 | 07:59 AM
JBrooke825's Avatar
JBrooke825
Default help
any other ideas. I sure could use the advice.
Old Feb 5, 2012 | 08:09 AM
dougbfresh's Avatar
dougbfresh
Start SEARCHING on the codes!!
Old Feb 5, 2012 | 09:19 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
OK,,, here are a few things for you to check. The lean code could be a vacuum leak. Check ALL the vacuum lines "especially" the PCV hose. The PCV hose is well known to ROT and cause a leak.
As for the U series DTC,, they are important and tell a story. They could have been caused by a low battery.
Make sure that the battery is fully charged and in good condition, and if it low recharge it. While its recharging, look at all your vacuum lines and make sure that there in good shape. Also check the connections from the MAF to the throttle body and make sure they are properly fitted and secure so there are no leaks.
Hope this helps.
Bill
Old Feb 5, 2012 | 09:29 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Recommend that you always include the year C5 that you have in the opening post. You have an 04 (I went and looked) which has a completely different PCV system that earlier cars 2000 and earlier. Some people who will try to help wont look may not provide you info for the correct year..
BC
Old Feb 6, 2012 | 08:35 AM
JBrooke825's Avatar
JBrooke825
thanks Bill,
yesterday I went out to find the battery dead. I got it started
and the CEL was off. maybe I cleared it the day before when I was getting the codes out. who knows. I took the bridge and the rest of the duct work off the intake( the varamm parts are very thin.) checked all the lines under the covers. the single bent PCV line seems fine a little soft but ok put everything back together. the car runs great and always has. the light is off for now we'll see if it comes back. I don't drive it enough thanks again. Jim
Old Feb 6, 2012 | 11:12 AM
dgrant3830's Avatar
dgrant3830
That PVC line/connection tube, can develop holes in it that are not easily seen...happened to mine. If its soft, replace it now. You can use fuel line from any store will work just fine.
Old Feb 6, 2012 | 06:01 PM
JBrooke825's Avatar
JBrooke825
thanks I"ll look at it again.
Old Feb 7, 2012 | 07:47 PM
JBrooke825's Avatar
JBrooke825
Default Cel
Well it didn't take long CEL is back. rechecked the hoses again,
the car does not have a miss. guess I"ll keep looking.
Old Feb 7, 2012 | 11:57 PM
cdkcorvette7's Avatar
cdkcorvette7
Just in case you haven't looked yet the code that is causing your issue is the P0171 which indicates that bank 1 (driver's side) is running lean. Lean codes are actually pretty common with vararams... did you just install your intake or have you had it for a while? Do you have a Z06 or a base C5? If a base, has your MAF been de-screened?
There are several things that can cause lean codes. See this post (one of many on the subject) for more info...
http://forums.corvetteforum.com/c5-t...r-vararam.html
Old Feb 8, 2012 | 08:14 AM
JBrooke825's Avatar
JBrooke825
the intake has been on for 5 or 6 years now. the light came on 6 months ago. MAFis not descreened. 04 Comm ED. all stock except for the varram and the bridge.
Thanks Jim
To check engine
