I need to replace the rear hub/bearing assembly in my C5. I found one on ebay, and was going to get two and replace both while I was at it. Does the same part number work on both sides...or is there a left and right side?
Thats not a true statement hoverer,, you can uses a rear hub on the front FRONT BUT,,,,,,,,,, you CAN NOT use a front on the rear. The connectors are also different front to rear..
Front HUB
REAR HUB
NOTE the hole in the center for the drive axle splines. The front hub does NOT have the hole for the axle shaft.
While it's possible to run the rear hub in the front, GM recommends against it for the standard hub. The C6ZR1 uses the SKF Race bearing, which is much stronger and can be used front and rear.
OP do your self a favor and do not purchase the crap Chineese hubs from Ebay. Spend a few extra $ and get SKF or Timken hubs from one of your local parts houses or search for them online. YOu will save yourseld a lot of $ in the long run.
The ones I am looking at on ebay are Raybestos hubs. Are they good or junk?
Great question!!! I take it for granted, but one of the only items I will buy from Autozone is the Timken wheel bearing/hubs
I must've swapped 100 in the past 10 years on C5's
Sadly people will pay over $500 from the dealer for a hub, on the high side(if racing/tracking) you could use the SKF ZR1 bearings
Front HUB
REAR HUB
BC
BC
Thank you, Bill, your photos say it all very clearly. I learned something from you
