Cammed, long tubes. Low MAP readings
Old Jun 23, 2024 | 03:04 PM
Jmsomm's Avatar
Jmsomm
Default Cammed, long tubes. Low MAP readings
BTr stage 3 cam. MAP reading is about 9 inhg at idle, and doesn’t appear to ever go above 20 inhg no matter load and RPM. When key is in ON position, it reads 29.63inhg. Shouldn’t I be seeing that reading at WOT?
Old Jun 23, 2024 | 03:52 PM
Prop Joe's Avatar
Prop Joe
Intake leak?
Brake booster hose not connected....
Old Jun 23, 2024 | 03:55 PM
Jmsomm's Avatar
Jmsomm
Originally Posted by Prop Joe
Intake leak?
booster hose is connected. I did just put new fel-pro intake manifold gaskets on.
Old Jun 23, 2024 | 04:41 PM
aaronc7's Avatar
aaronc7
This 9 inHG at idle... is this 9 inHG of absolute pressure or 9 inHG or vacuum?
It's my assumption these are absolute readings... 9 inHG is about 30 kPa which is lots of vacuum, definitely not right for a cammed motor. My 226/230 113 cam is around 50 kPa at idle.
What kind of gauge is this or are you reading the factory MAP? Aka how reliable do we think this is.
Old Jun 23, 2024 | 04:43 PM
Jmsomm's Avatar
Jmsomm
I’m reading the factory MAP from the live data of my scanner. What would cause an engine to have too much vacuum?
Old Jun 23, 2024 | 05:04 PM
aaronc7's Avatar
aaronc7
What RPM is it idling at? If you had a big vacuum leak + high idle, it could read pretty low vacuum. Doesn't explain the issue at high load though.
Not sure what kind of scanner it is, but a quick data capture might help ID if anything looks amiss.
Old Jun 23, 2024 | 05:07 PM
Jmsomm's Avatar
Jmsomm
car idles at around 900-950. Sometimes when coming to a stop, or when I start it up again after it’s warmed up, it wants to die unless I modulate the throttle a little for a few seconds then it will smooth out and idle just fine. However I most definitely don’t feel a misfire when this is happening. I’ve never seen it idle higher than about 950 ever.
Old Jun 23, 2024 | 05:14 PM
Vox Machina's Avatar
Vox Machina
You're sure you have a 1-bar MAP sensor? How old is the sensor?
Old Jun 23, 2024 | 05:17 PM
Jmsomm's Avatar
Jmsomm
I honestly don’t know. I’ve owned the car for a couple years and I never changed it.
Old Jun 23, 2024 | 07:14 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
KOEO at sea level your BARO should read around 29.9 inHg or about 101 kPa…at idle to read manifold vacuum subtract MAP from BARO…29.63-9.00 equals 20.63 inHg manifold vacuum…as idle increases your MAP inHg should decrease…you will need to check the wiring on your MAP sensor…a 5 volt reference, signal, and a Low Reference (ground)…if your MAP inHg does not change you may have a bad MAP or bad ground…to check MAP you will need to disconnect the MAP and with KOEO you should see 5 volts on the reference wire…you can jumper the 5 volt reference to SIGNAL and you should see 5 volts on your scan tool reading MAP voltage…connect test light to B+ and probe the low reference…test light should illuminate.
Old Jun 23, 2024 | 07:45 PM
Jmsomm's Avatar
Jmsomm
okay thanks. I noticed it seems to hit the highest number I’ll see (19 inhg or so) and doesn’t really fluctuate much if at all after that regardless of RPM and load. Hoping I just have a bad sensor/ loose connection. This is probably a dumb question, but could a bad Map sensor effect fuel trims?
Old Jun 23, 2024 | 08:06 PM
aaronc7's Avatar
aaronc7
Yes, the airflow model/fueling calculation are primarily from the MAF, but the speed density/VE model plays into it... incorrect MAP would really throw off that aspect of the fueling calcs.
Old Jun 23, 2024 | 08:14 PM
Vox Machina
Unless when it was tuned it was set to run on MAF only. Not a great choice, but one I've seen lazy tuners do.
Old Jun 29, 2024 | 02:42 PM
Jmsomm's Avatar
Jmsomm
little update. I switched the units of measurement to KPA for the MAP. I believe I had an issue with the scanner I was using. MAP Reading gets up to 97 under heavy acceleration, however I noticed as soon as I let off the gas, the readings drop all the way into the 20s for a second before jumping back up to 50-55. I’m assuming this is from a vacuum leak?
Old Jun 30, 2024 | 08:34 AM
aaronc7's Avatar
aaronc7
MT or auto? MT will get a ton of vacuum decel in gear, I'm not sure what's normal for autos.
What is MAP at idle now?
Old Jun 30, 2024 | 09:01 AM
Jmsomm's Avatar
Jmsomm
car is a manual. idle is 55-57
Old Jun 30, 2024 | 09:34 AM
aaronc7's Avatar
aaronc7
That sounds very reasonable for the cam in question.
Doesnt sound like you have a vacuum leak. but fuel trims or throttle position could indicate otherwise.
Old Jun 30, 2024 | 09:49 AM
Jmsomm's Avatar
Jmsomm
okay, thank you. Still trying to figure out my high fuel trims at idle only. Only on one bank.
Old Jun 30, 2024 | 10:07 AM
C5 Diag's Avatar
C5 Diag
High fuel trims only on one bank would not indicate a vacuum leak like an intake leak downstream of the MAF sensor which would be both banks…if the fuel trims decrease at 3000 RPM you may have an exhaust leak upstream on that bank of the front O2 sensor or an intake runner leak.
To Cammed, long tubes. Low MAP readings
