Battery Drain Still
Old Feb 6, 2012 | 08:40 AM
ravye's Avatar
ravye
3rd Gear
Default Battery Drain Still
When I connect the battery I hear what sounds like a relay engaging in the area of the right side headlight. I do this with the twelve disc changer door open so I don't have to listen to that. I guess my question is is there a relay down there and should it do this? Any help would be appreciated. Dick Vye This is the first time I have posted a question and got no reply's. Have I stumped the experts? I find that hard to believe. Thank you, Dick Vye my question still is do all c5,s do this ?
Last edited by ravye; Feb 8, 2012 at 08:23 AM. Reason: Have received no responses.
Old Feb 8, 2012 | 04:21 AM
gsixl's Avatar
gsixl
I have a 98 and 00 you can hear the same relay when connecting the battery. It will click several times if you don't get a good connection at first.
Old Feb 8, 2012 | 04:25 AM
gsixl's Avatar
gsixl
As for the battery drain? I do know you will need a darn good battery if you let these c5s set for over a week without starting and driving them. If your battery is on the way out it may not stay up a couple of days.
Old Feb 8, 2012 | 10:28 AM
chaase's Avatar
chaase
St. Jude Donor '12
If yours can't sit for a week without dieing you have a drain somewhere. I know many people that can go 4-6 weeks without the battery dieing.
Old Feb 8, 2012 | 11:08 AM
old stingray's Avatar
old stingray
Do you have a full charge on your battery,good clean battery connections.Is your heater ac controls on,it could be your compressor switch you hear. Good luck
To Battery Drain Still
