NEED HELP installing UD pulley
Old Feb 6, 2012 | 09:17 PM
parks450's Avatar
parks450
Default NEED HELP installing UD pulley
Ok I posted this up not that long ago about not being able to get my Powerbond UD pulley on and I thought I got it but am still having problems. All my other stock pulleys have sat flush with the crank but I have never had a UD pulley so Im not sure if this is correct. I have installed a stock pulley a few times with no problems but this one went on harder than normal. I got it to this point and it got to the point where I was fighting it to get it on anymore. Also it doesnt look like it wont go on any farther and my crank pulley and water pump pulley are perfectly inline. Here are pics, Let me know what you guys think.
Old Feb 6, 2012 | 11:15 PM
parks450's Avatar
parks450
Bump
Old Feb 7, 2012 | 08:42 AM
VET IT B's Avatar
VET IT B
The first pic looks correct. It doesn't go flush. I will try to get the correct offset measurement, if I can find it.
Here is a pic of mine.
Old Feb 7, 2012 | 12:20 PM
parks450's Avatar
parks450
Thanks for the pics bud. What's your measurement from the crank snout to the face of the inner hub?
Old Feb 7, 2012 | 04:39 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
This is going to sound weird but it has worked EVERY TIME for me. Use a propane torch and heat up the HUB portion of the damper until its approx 200 deg. It will not take long and if you just heat the hub, it will not hurt anything on the damper crank seals or engine.
Once its at temp, use a damper install tool and it SHOULD slide on easier! If it wont go on any further. Let it cool over night and once everything is cool, reheat the HUB and REMOVE the damper and inspect the damper, crank snout and cover.
HEAT IS YOUR FRIEND! I used a little bit of wd-40 on the snout and damper and heated it up and it went on a WHOLE LOT EASIER than I ever expected!
Here is my home made damper install tool. I also use a giant strap wrench and I can install it and properly torque it myself. I also up graded to an ARP Damper Bolt. Well worth the $25.
Old Feb 7, 2012 | 06:43 PM
parks450's Avatar
parks450
Bump anyone else
Old Feb 7, 2012 | 11:46 PM
rodsvet's Avatar
rodsvet
If it was mine, I'd pull the pulley back and mike it and then mike the crank snout. If you are using a tool to install and it stops totally there is a reason. You say that the crank and water pump are perfectly in line and you still have a 1/2 inch to go is a red flag to me that maybe you don't have a balancer for a c5. Maybe I'm misreading your post. It is a really tight fit but I remember you posting about this a while back and They just aren't that hard to install. Bill is right on about the heat. Have you tried it? Good luck Rod
Old Feb 8, 2012 | 05:14 AM
vettenuts's Avatar
vettenuts
One of the steps in the GM installation procedure is a measurement from the edge of the pulley hub to the tip of the crank (how deep is the crank recessed). The distances provided in the manual are obviously for a stock unit. When I did my ATI, I re-measured the hub length as compared to stock so I could establish the correct depth measurement with the ATI hub. The only way to perform this step with the PB is to know the hub length and how it compares to stock. Once you have this and take the measurement you will know if the pulley has bottomed. Everything else at this point is just a guess.
I also agree with rodsvet as I have seen where several guys have received the wrong part number and although it looks correct it is not.
Old Feb 8, 2012 | 06:25 AM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
I was having this problem and found out that SLP had sent me one from a Z28 camaro instead...
Old Feb 9, 2012 | 08:42 AM
nullpointer's Avatar
nullpointer
I used the Hawk install tool and mine went on father than that.
I highlighted with a red line the distance, since it's not the easiest to see after the black coating is rubbed off the UD balancer.
Old Feb 9, 2012 | 09:24 AM
lionelhutz's Avatar
lionelhutz
It doesn't look on far enough to me.
You need to confirm the part number and then confirm the interference fit. I don't know for sure but it likely should have an interference fit something around 3 thousanths of an inch. The manual should have the info. Then, you heat the hub and press it on. If you're not sure about the torch, heat the oven to 200 degrees and throw it in there for 10 minutes before installing.
Peter
Old Feb 9, 2012 | 10:04 AM
parks450's Avatar
parks450
Yea im Going to try heating her up. It doesn't help the tool I made which is basically identical to the hawk tool, it was binding on the threads inside and I couldn't turn it even just holding it without a lot of force. So I may pick up the hawk tool and give her a try, anyone else think its overpriced? I built two of them basically identical and it was under $30. If I would have taken more time I could have perfected it
Old Feb 10, 2012 | 11:32 AM
rodsvet's Avatar
rodsvet
Lionelhutz made a good suggestion on using the oven. You may get carried away with the torch and over heat the elastomer of the new pulley. good luck, Rod
To NEED HELP installing UD pulley
