Headlight lubing
Old Feb 7, 2012 | 01:16 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Default Headlight lubing
Can the headlight mechanism be lubed as a matter of preventative maintenance?
If so, where........?
Old Feb 7, 2012 | 10:47 AM
toddk's Avatar
toddk
You might want to look at the assembly before asking something like this. Are you having a specific problem?
The headlight hinge points use dry teflon bushings. The motor has an actuator arm to open the door, and travels a range limited by bump-stops. The motor has a sealed plastic drive gear inside. When (not if) it fails, you will be re-lubing a big brass gear, or buying a new motor.
Usually the headlight motor gear will strip out, as the range limits are sensed by a high current draw when the motor binds. Repeated binding eventually chews up the gear. There are several threads on the gear replacement if you search.
Todd
Old Feb 7, 2012 | 12:08 PM
Oldvetter's Avatar
Oldvetter
The headlight aiming adjusting screws (plastic) can and should be lubed, especially BEFORE trying to adjust them. You can not get these parts anymore.
To Headlight lubing
