ebtcm help please
Old Feb 8, 2012 | 12:23 PM
sunkship's Avatar
sunkship
2nd Gear
Default ebtcm help please
I'm trying to troubleshoot a 2000 vette standard with the 5.7L engine. It keeps giving codes C1225, C1233, and C1255. Thanks in advance for any help or advise given.
Old Feb 8, 2012 | 02:13 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What is the status of the following????? Please provide the info requested:
- Battery condition and age
- Voltage at EACH of the EBTCM fuses to Chassis ground with the ignition switch ON
- Chassis ground connections G-101 and the EBTCM ground eyelet under the G-101 ground tab
- The ground lug on the EBTCM motor
Are the codes HISTORY or CURRENT???????????
BC
Old Feb 8, 2012 | 07:50 PM
sunkship's Avatar
sunkship
2nd Gear
Please bear with me. New to this, so trying to play catch up and I apologize in advance.
Can you help me locate the ground connections? I clear the codes and they come back almost as soon as I start the car so I'm going to lie and say current and not history. Been using battery charger to keep up with keeping battery charged as this car has always been known to run down a battery in a couple weeks if it's not driven regularly; but with the extra attention with charger seems to do fine.
EBTCM fuses are which ones and where are they located?
Old Feb 8, 2012 | 11:38 PM
Dave68's Avatar
Dave68
Another thing to try if getting bad ground codes is to unplug and plug the two EBCM connectors. I was getting a persistant bad ground code, even after cleaning all the ground connections. I then unplugged and plugged a few times and the code (1242?) never came back again.
Old Feb 9, 2012 | 08:52 AM
red89c4's Avatar
red89c4
check out the below. it is a great write up by BC. your problem probably lies within the contents. GL.
http://forums.corvetteforum.com/c5-t...tion-long.html
To ebtcm help please
