Quick! How Do You Seperate the Lower Front Ball Joint?
Old May 13, 2002 | 11:16 PM
gpflepsen's Avatar
gpflepsen
Cruise-In II Veteran
Default Quick! How Do You Seperate the Lower Front Ball Joint?
I've got a call from another Vette Bro who can't get the lower front ball jount off. How do you remove it without the ball joint seperator?
Old May 14, 2002 | 12:41 AM
joeflyer's Avatar
joeflyer
Default Re: Quick! How Do You Seperate the Lower Front Ball Joint? (gpflepsen)
Once you get the nut off, support the (spindle) rotor with a floor jack. Wrap on the top of the ball joint with a 2X4 and hammer. I had to lightly hammer on the side of one to break it loose.
Old May 14, 2002 | 09:04 AM
99 Corvette's Avatar
99 Corvette
If you are lowering you can just unbolt the upper a-arm from the car (it is held on by 4 bolts at the top of the wheel well) and swing the whole thing down to get access to the adjuster bolt :yesnod: Much safer than jacking the car up from the rotor.
Jerry
Old May 14, 2002 | 06:28 PM
RadarBlue's Avatar
RadarBlue
Default Re: Quick! How Do You Seperate the Lower Front Ball Joint? (joeflyer)
...or you could spend $5 and buy one.....
Old May 14, 2002 | 06:36 PM
99 Corvette
Default Re: Quick! How Do You Seperate the Lower Front Ball Joint? (RadarBlue)
I assume you are talking about a seperator :confused: That is not a good idea. There is a rubber boot in the way that you would tear up if you used a seperator.
Jerry
Old May 15, 2002 | 12:26 AM
RadarBlue's Avatar
RadarBlue
Default Re: Quick! How Do You Seperate the Lower Front Ball Joint? (99 Corvette)
It's like everything else...you just have to be careful.
To Quick! How Do You Seperate the Lower Front Ball Joint?
