Cluster Turn Signal Lights
Old Feb 13, 2012 | 10:42 AM
defconfire's Avatar
defconfire
Default Cluster Turn Signal Lights
I have a 2002 Z06 with an interesting issue. Intermittently, and now more frequently than not, my gauge cluster indicators (the little green arrows) wont come on, however the exterior bulbs and the indicators on the HUD work fine.
I've done some research and I think it may just be a bulb however I cant find any specs/part numbers on it. Another possibility may be a grounding gremlin (my car has had electrical gremlins with the memory mirrors and other misc stuff since day one)
Any input would be great
Old Feb 15, 2012 | 09:22 AM
defconfire's Avatar
defconfire
Anyone?
Old Feb 15, 2012 | 01:32 PM
DeeGee's Avatar
DeeGee
I'd say its a problem on the IPC. If it was a bulb you'd get rapid flash.
Old Feb 15, 2012 | 03:03 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I believe the turn signal lamps in the IPC are replaceable but truly I don't know if they are neo-wedge types or something simple like a 194 lamp.
Old Feb 15, 2012 | 07:04 PM
craig04c5's Avatar
craig04c5
I had an intermittent issue also but it affected the dash turn signals AND HUD turn signal. The outside turn-signals were fine however. Turned out to be a mirror memory issue (broken mirror base plate).
To Cluster Turn Signal Lights
