Socket size for lug nuts
Old May 14, 2002 | 11:27 AM
Theblkraven's Avatar
Theblkraven
Default Socket size for lug nuts
I know this is a simple question, but I just want to make sure. I tried a 3/4" and a 19mm socket on my lug nuts('99 c5), and they both seem to fit. Which is the correst size to use. Thanks for the info. :)
Old May 14, 2002 | 11:38 AM
jobarn's Avatar
jobarn
Default Re: Socket size for lug nuts (Theblkraven)
They appear to be the same size to me also. I use the 3/4" since it is hex and matches the lug nuts.
Old May 14, 2002 | 11:40 AM
MySea6's Avatar
MySea6
I use a 19mm, deep & hardened :yesnod:
Old May 14, 2002 | 01:07 PM
CALVette's Avatar
CALVette
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Socket size for lug nuts (MySea5)
I use the 3/4 to take off the covers and the 19 for the lug nuts.
It's a good idea (IMHO) to use a 19mm deep when using your torque wrench to tighten your lug nuts.
[Modified by CALVette, 9:07 AM 5/14/2002]
Old May 14, 2002 | 01:14 PM
BostonVette's Avatar
BostonVette
The difference between 19mm and 3/4" is .002". The 19 mm is tighter.
I use a 19 mm deep with a torque wrench set to 100 in-lbs, but then, I like to mix my units.
Tom
Old May 14, 2002 | 01:18 PM
JerryL's Avatar
JerryL
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Socket size for lug nuts (CALVette)
The conversion factor is: millimeter x .03937 = inch, so 19 mm is .748 pretty close to 3/4".
Old May 14, 2002 | 03:18 PM
C54CSTER's Avatar
C54CSTER
Default Re: Socket size for lug nuts (JerryL)
The lug nuts on my '01 Z have "Metric" engraved right on them, so i have always used the 19mm in favor of the 3/4". :yesnod:
Old May 14, 2002 | 06:52 PM
Theblkraven
Thanks to everyone for the info. The 19mm sounds like the way to go. :)
To Socket size for lug nuts
