O2 Sensor Question.
Old Feb 24, 2012 | 12:27 AM
  #41
chevy406's Avatar
chevy406
I setup my tune to run OL from idle up to 1200 rpm. Above 1200 it switches back to closed loop. I have my idle AFR fairly lean to help with fuel economy and it gives a little more choppy idle. I do have a little surge at low rpm cruise (like through a parking lot or construction zone). It's just the trade off with having headers and a mid-size cam.
Old Feb 24, 2012 | 07:53 AM
  #42
RonSSNova's Avatar
RonSSNova
Can you elaborate on how this is done with RPM as the trigger?
Ron
Old Feb 24, 2012 | 08:12 AM
  #43
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by Trios
I actually think it's quite possible you can get a better tune and a smoother engine without the O2s, as the PCM is programmed to run rich/lean cycles to properly burn off hydrocarbons and CO, each of which requires different oxygen content. An excellent tuner with good data can smooth this out so the engine runs stoichiometric all the time.
Good explanation, thanks.
Old Feb 24, 2012 | 09:02 AM
  #44
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
Ron
it's a hybrid tune. do a search on the HPTuners forum and there are lots of info on how to do thus.
I think there is some here: http://www.hptuners.com/forum/showthread.php?t=36318
Old Feb 24, 2012 | 09:47 AM
  #45
RonSSNova's Avatar
RonSSNova
Ok, thanks.
Just absorbing knowledge here as I will face all this stuff when I get my car on the road this spring.
Ron
Old Feb 24, 2012 | 10:08 AM
  #46
chevy406's Avatar
chevy406
Thanks for providing the link Printman... it was late last night when I posted that, and I still had to install the exhaust pipe and O2 sensors on the 2004 that I am working on. I finished it around 1:15 am and got back up for work at 5:30. All I have to do when I get home is upload the startup tune and hit the key. Hopefully I'll be turning it back over to the owner this weekend, after having it in my garage for 3 weeks.
Old Feb 24, 2012 | 01:22 PM
  #47
mickey_7106's Avatar
mickey_7106
Old Aug 29, 2013 | 01:00 AM
  #48
Chaplain's Avatar
Chaplain
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
