Crank bolt puller help
Old Feb 19, 2012 | 07:58 PM
vettegirl925's Avatar
vettegirl925
Default Crank bolt puller help
Which is the proper puller to use on crank bolt to get balancer off
Old Feb 19, 2012 | 08:24 PM
Lothar34's Avatar
Lothar34
If you have a stock balancer, then one like what's shown under Part 4 on this page:
http://ls1howto.com/index.php?article=1
Old Feb 19, 2012 | 08:40 PM
Paul 75 L82's Avatar
Paul 75 L82
And it has to be the correct size. I went to buy one and it was too big to fit the balancer.
Old Feb 19, 2012 | 11:03 PM
timewstr's Avatar
timewstr
Default balancer puller
O'rileys or Kragen will rent you one for a Chrysler balancer that works great on the LS1. Looks like the one listed at Amazon.
http://www.amazon.com/CTA-Tools-A810...sim_sbs_auto_2
Old Feb 20, 2012 | 08:22 AM
fendermender's Avatar
fendermender
Yep, the one listed for Chryslers works perfect. I rented the balancer kit from Advance Auto. However it didn't have the adapter to install. I had to make one using an old bolt and some mig welding.
Old Feb 20, 2012 | 10:33 AM
vettenuts's Avatar
vettenuts
Make sure you push on the end of the crank snout, not on the old bolt as recommended by ls1howto.com.
Old Feb 20, 2012 | 11:00 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you use a heat gun or propane torch to apply some heat to the HUB portion of the damper it will make removal and installation much easier. Doesnt take much heat (130-150 deg)
Make sure that you use an installation tool to reinstall the new damper. I as well as others make their own.
MAKE SURE you follow the GM Service manual to the letter on installing the damper and torquing the BOLT! I upgraded to the ARP damper bolt! Much easier and its reusable.
BC
To Crank bolt puller help
