Better wheel/tire combo for performance?
Right now the car has chromed CCW 505A wheels, 19 x 10 in the front 19 x 11 in the rear, mounted on P-Zero Rossos, 275/30/19 front and 305/30/19 rear.
If I went down to stock C5 sizes, using a C6 Spyder reproduction 17/18 combo, how much am I helping myself?
I'm also considering an 18/19 set up, but it would still use the giant 305/30/19.
I'm trying to squeeze all the performance I can out of this thing without tearing the engine open.
for "ALL" the performance you can get, consider 17" on all fours
Much lighter
For each 1 lb or rotating mass removed, is ~ 6-6.5lbs of static mass removed. Plus the further way from the center of rotation that mass is the more work to accelerate and brake.
each 100 lbs of Mass removed could be equivalent to 10 HP gained
Mass, specifically rotating mass kills performance.
That said, 18" tires are easier to get the 17" tires.
Dont go too wide, and keep the front slightly less wide then the rear.
No run flats, they add too much wt to the tire.
and sticky tires, Nittos or Toyos are very good and sticky street tires.
dont expect too much life out of them either. Maybe two years, 5000 miles if that.
The hard part to qualify is the inertia of the wheels. The inertia affects the amount of power required to get the wheels spinning and the amount of braking energy required to stop them from spinning. Bringing the wheel mass closer to the middle of the wheel would lower the inertia which should increase performance, even if the wheel mass was the same.
Peter
