Header Install
Old Mar 6, 2012 | 09:06 PM
edusmc1's Avatar
edusmc1
Default Header Install
Completed header install today and looks and sounds good, car runs and idles great. Noticed when driving and on take off pressing the gas slow and easy I hear sucking noise that seems louder than with the stock exhaust. Not sure if this is normal or not, I went back and checked to see if I left anything disconnectec but all looks good.
edusmc124
USMC 28 yrs Active
Old Mar 6, 2012 | 09:20 PM
04C5-in-MD's Avatar
04C5-in-MD
Cruising
If you can hear anything over the exhaust boom you need a new exhaust. LOL.
Old Mar 6, 2012 | 09:39 PM
m6 c5's Avatar
m6 c5
I dont think you should hear a sucking noise, that would tend to be associated with a new intake.
Old Mar 7, 2012 | 06:30 AM
kmetros's Avatar
kmetros
Since you just removed a bunch of stuff it is possible that something was left disconnected. Did you remove the intake? Could be one of the vacuum lines on the back of the intake didn't get reconnected?
Also remember that the walls of the headers are much thinner than the cast exhaust manifolds that came off of there. Headers are known to be a bit 'noisier' than a stock exhaust system - meaning you will hear more noises than you did before, even when you change nothing else.....they are all sounds that were there, but were masked by the heavy manifolds.
Old Mar 7, 2012 | 09:31 AM
bumble-z's Avatar
bumble-z
Which manufacture of header, used?
Which exhaust header gaskets were used?
Air pump disconnected or rebolted to headers? Possible air leak at the connections/gaskets?
Old Mar 7, 2012 | 09:45 AM
rclinton's Avatar
rclinton
Veteran: Marine Corps
If you need another set of eyes, Im right up the road. Besides I would love to hear the headers!
Bob
Old Mar 7, 2012 | 09:48 AM
Orig Ante M's Avatar
Orig Ante M
Are you guys replacing the header gaskets when installing LT's?
Old Mar 7, 2012 | 09:59 AM
bumble-z's Avatar
bumble-z
Most throw the abestos style gaskets from the header company away,
& don't use them.
Go with new, GM steel LS/1 gaskets.
Old Mar 7, 2012 | 10:14 AM
Orig Ante M
& don't use them.
To Header Install
