Piston slap. Class action lawsuit.
Old Mar 19, 2012 | 12:18 PM
  #41
dougbfresh's Avatar
dougbfresh
Originally Posted by Quicksilver Vert 01
Time for a Class Action Lawsuit against Nissan?
Doubt you'll get much farther than the GM owners did-nice to see the Ricers have the same issues. Doesn't seem to hurt the reliability.
Old Mar 19, 2012 | 01:07 PM
  #42
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Old Mar 19, 2012 | 05:50 PM
  #43
JonLT4CE's Avatar
JonLT4CE
Originally Posted by Rusty34
Then you should go listen to an original 1970 LT-1 start up. Besides noisy loose forged pistons you get loud clatter of solid lifters.
This is a non-issue except for the nitpickers. If you need quiet pistons when the engine is cold maybe you should consider getting a Buick or a Cadillac. The Corvette is a high performance car and with high performance there are sometimes compromises which must be expected. Tighter piston to wall clearances are quieter during operation but tighter clearances also hurt power due to higher friction.
This is why manufacturers usually specify cast pistons. Cast pistons don't expand as much during warm-up thus can be installed with tighter piston to wall clearance. Cast pistons installed a little looser will be noisy when cold but will make more power. There is a tight window between noise when cold and no noise. You could fix it by replacing with slightly larger pistons but it would be more work than the effort is worth and if you could compare the results on a dyno the engine would make slightly less power afterwards, however, the "quietness" nitpickers probably prefer quiet over power.
You mean a Cadillac such as the CTS-V? I would consider that, having driven one on the track.
-Jon
Old Mar 20, 2012 | 06:00 AM
  #44
ZMX's Avatar
ZMX
Heavier oil will just lubricate worse.
Don't run the car hard before it's warmed up. It won't be a problem.
Old Mar 21, 2012 | 03:01 PM
  #45
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Originally Posted by 540 vette
So the question is how do you sell a car to somebody. How do you explain it to them. I would expect a corvette guy to do his homework. But a guy looking at his first LS1 might be a little surprised.
Sell it on this site may not get as much grief for piston slap and any one else that has an issue with it isnt worthy of driving such a fine piece of machinery
Old Mar 21, 2012 | 03:33 PM
  #46
dougbfresh's Avatar
dougbfresh
If you think it's a big deal, have a new set of pistons put in.
