Piston slap. Class action lawsuit.
Old Mar 11, 2012 | 06:52 PM
540 vette's Avatar
540 vette
Default Piston slap. Class action lawsuit.
Has anyone heard of a class action suit going on now on the early c5's with this problem.
My car has it on startup. I've had the car for 9 years and it has never changed. And it goes away after it is warmed up. I don't worry about it because I know what it is. But I am trying to sell the car and it is hard to explain to someone that doesn't know. I tell them to just read what is on the internet. If you are buying this type of car anyway you should do your homework.
Old Mar 11, 2012 | 06:53 PM
dougbfresh's Avatar
dougbfresh
Never happen especially with the bankruptcy-what's the problem-9yrs and your still going.
Old Mar 11, 2012 | 07:44 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What viscosity oil do you use? Have you tried a heavier weight oil?? Something like 10w-30 instead of the 5W-30 recommended.
BC
Old Mar 11, 2012 | 07:55 PM
fevest's Avatar
fevest
The only person that wins with a class action is the lawyer. As someone else said. 9 years and still going. Doesn't seem like too much of a problem.
Old Mar 11, 2012 | 07:59 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I've never had this issue in my super high mileage '99 but I do have this issue in my '07
Old Mar 11, 2012 | 08:07 PM
540 vette's Avatar
540 vette
BC
Yes I have the heavier oil in it.
Old Mar 11, 2012 | 10:27 PM
walleyejack's Avatar
walleyejack
Make sure it is warmed up before you sell it.
Old Mar 11, 2012 | 10:39 PM
Bill Dearborn's Avatar
Bill Dearborn
What problem? A noise doesn't always mean there is a problem. So far I have not heard of anybody showing there is a problem. No problem no class action suit or any suit at all. Does your car have any issues with excessive oil consumption, does it have reduced power, are you experiencing increased maintenance costs?? Machines make noise some machines make different noises than others. Once I found out it wasn't an issue after I took delivery of my 97 I never worried about it. Had two C5s over a period of 12 years and both of them had piston slap or whatever was causing the noise. By definition a quality problem only exists if a product can't perform as intended. Since the noise doesn't hinder the engine from performing in its intended manner it isn't even a quality issue.
Bill
Old Mar 11, 2012 | 10:41 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I too don't think it will ever happen - but it is what it is and there might even be a statute of limitations on it too -
Had it on mine but since doing a forged set-up it is all solved
Thanks,Matt
Old Mar 11, 2012 | 10:59 PM
540 vette's Avatar
540 vette
The reason I am asking is that a potential buyer of my car asked a chevy tech friend of his if the slap was a problem. The guy said that the 99's were the worst. I told him to do a search on it. I think he is going to use this to drive the price down. At the price I am selling it at it isn't going down much.
Old Mar 11, 2012 | 11:03 PM
duramaxsky's Avatar
duramaxsky
Good that's what that noise is when it's cold sometimes. Now I won't worry about it anymore.
Old Mar 12, 2012 | 12:20 AM
rodsvet's Avatar
rodsvet
Mine has a slight sound for 2 minutes or so. When warmed up it makes no noise. Been that way for 12 years. I used to worry a little after going supercharged but I just let it warm up before boost. Hey Matt is your ride back together? Didn't see a post on it. Rod
Old Mar 12, 2012 | 02:39 AM
Bluefire's Avatar
Bluefire
Mine went away when my wallet warmed up and sprung for a H/C package.
Old Mar 12, 2012 | 07:28 AM
AU N EGL's Avatar
AU N EGL
Piston slap? first chevy I am guessing.
Old Mar 12, 2012 | 09:01 AM
540 vette's Avatar
540 vette
First LS 1. I have had Chevy motors for the last 35 years. Big ones and small ones. I have never had this on any of them. Just my race motors.
Old Mar 12, 2012 | 09:57 AM
AU N EGL's Avatar
AU N EGL
Piston slap is common with just about all SBC engines. No big deal.
just warm the engine up a bit. use 10-w30 oil, or put an accu-sump to prelub the block. But that may be going to far.
Old Mar 12, 2012 | 10:01 AM
dgrant3830's Avatar
dgrant3830
I can easily state that my '99 has been a great car. No piston slap ever with it and now at 326k miles. Bottom end has not been apart yet.
To Piston slap. Class action lawsuit.
Old Mar 12, 2012 | 01:56 PM
DeeGee's Avatar
DeeGee
I have to say that the LS1 is one of the best engines I have ever owned; piston slap or not.
Old Mar 12, 2012 | 05:04 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Heavier oil will do next to nothing to quiet down piston slap, as you have seen.
There is no pressurized lubrication, at the base of the pistons, where the slapping occurs. The only lubrication in that area, is just a very small amount of oil splash.
Old Mar 12, 2012 | 05:14 PM
sunchaser73's Avatar
sunchaser73
dgrant...original motor...326K...?...326,000...Just asking...if true, very, VERY impressive!
