Header gasket
Mar 11, 2012 | 08:05 PM
Header gasket
Gentilmen
Need help on what's the best header gasket to use on the LS engines, I installed new headers and the factory gaskets they provided, gaskets lasted 2 days before one started leaking on passenger side and it has a code P1153 now. Need to fix this week but I want the best gastet and I know you guys have done this for a long time and have the correct answers. Thanks alot....
Robert
edusmc124@live.com
usmc active 28 yrs now....
Mar 11, 2012 | 08:14 PM
Pretty sure the factory GM gasket is the best.
Mar 11, 2012 | 08:45 PM
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Stock GM metal gasket!
Mar 11, 2012 | 09:20 PM
Quote:
Originally Posted by
Bill Curlee
GM Metal exhaust manifold gaskets (2x GMPN 12558573)
Mar 11, 2012 | 10:21 PM
if anyone gives you another answer besides gm mls gaskets then they are wrong
Mar 11, 2012 | 10:24 PM
GM gaskets,, you can use same ones 2 or 3 times with no problems.
Mar 11, 2012 | 11:00 PM
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Bill Curlee
This is what I used on my headers and all my friends too! Work like a champ and the Multi Layer Steel (MLS) is the best you can get
Thanks,Matt
Mar 12, 2012 | 02:20 AM
Mar 12, 2012 | 07:35 PM
Header Gaskets
Thanks everyone for the information on the gasket. I will be odering them this week. Thanks alot for the great advise!!
Robert
edusmc124@live.com
USMC
Mar 12, 2012 | 07:39 PM
Mar 12, 2012 | 07:40 PM
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thanks for serving!!!!!!!!!!!!!1
: cheers:
Bill Curlee Retired FTSC (SS) USN
Mar 13, 2012 | 07:34 PM
Bill Curlee
: cheers:
Thanks alot Bill same to you, I have 23 months to get to 30 if my body will hang on LOL!!!!
Mar 13, 2012 | 08:09 PM
CI 6,7,8,9,11 Vet
St. Jude Donor '08
edusmc1
HANG IN THERE BUD! That check of the month club is awfully cool!
Bill
Mar 13, 2012 | 08:25 PM
St. Jude Donor '06-'07-'08-'09
if you're blowing the factory gasket you need to check the header flange to make sure it's flat. I have seen it before that the flange has to be belt sanded to make it flat so it seals correctly.
Mar 13, 2012 | 08:40 PM
If you didn't destroy them, then just pull the old factory ones out of the trash and put them back on...
Mar 14, 2012 | 05:32 AM
The gaskets that came with my header were junk. I put the three piece factory used gaskets back on and have no problems.
HTH
