Do I need a full retune
Old Mar 21, 2012 | 10:36 PM
paladin85's Avatar
paladin85
Default Do I need a full retune
Posted this over in Scan/Tune. Obviously the wrong place.
I had H/C/I CAI and Headers installed a few months ago. My idle is all screwed up. I have no confidence in the local tuner being able to fix then problem I'm having of the rolling hanging idle, high in gear idle etc. My question is do I need a full tune if I install a Fast 92/90? Will I damage the car if I drove it 4-5 hours to get a good tune after the intake install. I want a street tune I'm interested in the drivability of my car rather than how well the car dyno.
The car is a 98 A4 with a 224-230 114 cam
If you know of a good tuner within 4-5 hours of Pensacola I'd be interested.
Appreciate any feedback
Old Mar 21, 2012 | 11:01 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Sorry for your troubles but yes, you obviously need a tune. Why won't the "local" guy help? What configuration on your car did he tune?
Maybe more info might helps us help you,,,
Old Mar 21, 2012 | 11:31 PM
Lothar34's Avatar
Lothar34
Jeremy Formato is in Florida and he can tune it.
You're fine to drive it with the new intake, just don't go WOT.
Old Mar 22, 2012 | 12:01 AM
paladin85's Avatar
paladin85
The shop that did the work used their tuner. After taking it back for a couple issues with the tune, I lost confidence in the shop being able to properly tune the car. When the tuner told me that Automatics are hard to tune and I should stall the car and it will take care of my idle issues. I really researched my set up and it doesn't need a stall although I plan to stall the car later I want It' tuned correctly before I go screwing witht the transmission and shift points etc.
I'm going to find another tuner just wanted to know if i would need a full retune for an Intake manifold and TB swap.
Old Mar 22, 2012 | 12:12 AM
paladin85's Avatar
paladin85
Forgot to add what was done to the car.
The shop installed.
AFR205 Heads
ARH 1 7/8
CAM 224-230 114
VRB2 CAI
LS6 Intake
Full Dyno Tune
Issues:
Car Idles great in Park
Idle hang @1200 when rolling and in neutral.
Car Pulls through the brakes when shifting into rev or drive
I can put the car in drive and not touch the throttle and the car will go 40MPH
It doesn't take off but it will get up to 40 MPH with no Throttle input
Old Mar 22, 2012 | 12:21 AM
Lothar34's Avatar
Lothar34
You researched the setup and came to the conclusion that it didn't need a stall?
If it's pulling through the brakes then you might want to reconsider.
Old Mar 22, 2012 | 07:17 AM
AU N EGL's Avatar
AU N EGL
re tuning is always a good idea.
Old Mar 22, 2012 | 10:08 AM
chevy406's Avatar
chevy406
The '97 and '98 ECM is a little more difficult to tune than the later C5s, but it can certainly be properly done to make your 224/230 cam have good street manners. But I really do think you need to get that higher stall converter sooner rather than later. It will be difficult to get good street manners with a tight stock converter, and the higher stall converter will make a huge improvement in your car's performance.
To answer your question - yes you can drive the car with an upgraded 92mm FAST intake/TB. Certainly don't run it hard until you get it tuned. It may have a lot of trouble idling, just hard to say until you try.
Old Mar 22, 2012 | 10:24 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% absolutely you needed a tune. Was it done correctly??? Most likely NOT if your having all those issues!
An LS6 Intake and TB wont necessarily need a tune but your tune sounds like it never was correct.
CAM 224-230 114
If your going thru all the expense and trouble of getting a RETUNE, call Jeremy Formato and get his EXPERT recommendations.
If he recommends a higher stall converter,, DO IT! It will make your car drive so much better.
BC
Old Mar 22, 2012 | 10:27 AM
SaberD's Avatar
SaberD
an intake mani is easy enough to install. it shouldn't take anything but 20 minutes. find a good tuner, and bring the tools with you to do the install when you get there.
Old Mar 22, 2012 | 10:37 AM
LoneStarFRC's Avatar
LoneStarFRC
PM sent
Old Mar 22, 2012 | 10:46 AM
chaase's Avatar
chaase
St. Jude Donor '12
Issues:
The tune is wrong. There is no reason for the car to be idling at 1200rpm in neutral when it is warmed up, high stall converter or not. When I first got my car back after the pile of mods done, I had some of those issues. I called my tuner and told them what was going on and they said bring it on in. I took the car back in and they fixed it right back up. No questions asked, no complaints about doing it and no charge.
It can be difficult to get the automatics tuned perfectly the first time. There are more settings and every car responds to mods a little differently. Those problems should be handled easily and if the tuner is worth their salt, the will get it done.
Old Mar 22, 2012 | 01:55 PM
paladin85's Avatar
paladin85
How do I get a hold of Jeremy Formato? What part of FL. is he located in?
I do plan to stall the car but I want it properly tuned first. All the stall will do is mask my current issues. I do understand that the older A4s are tougher to tune.
I do worry about stalling the car and start having other issues.
Thanks!
Old Mar 22, 2012 | 02:18 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NOTE!! When you add a higher stall converter, you will need to tune the PCM AGAIN!! All the PCM transmission calibration characteristics will need to be re-calibrated to the new stall speed converter. Shift points, line pressures shift firmness etc...
Jeremy wont care if you have a new converter or not to tune it correctly If he is going to tune your car, he will most likely flash in a PCM program that already incorporates the MODs that you have from a library that he maintains and will only have to fine tune the PCM from there.
Give him a list of the mods that you have installed and the converter specs and it will be correct!
Heres a post that you can use to PM him:
http://forums.corvetteforum.com/c5-s...r-23-29-a.html
http://www.fasterproms.net/ Or this site..
Old Mar 22, 2012 | 06:24 PM
rootpooty's Avatar
rootpooty
like others have suggested i would def look into a stall and if your feeling froggy i would add a set of 342's out back to maximize the combo. send me a pm if you would like to sell the ls6 intake if you find a fast setup
To Do I need a full retune
