car wont start .....flooding
Old Mar 22, 2012 | 01:57 PM
whosnext's Avatar
whosnext
Default car wont start .....flooding
Car is at body shop and was running fine, they drove it around to get to one area to other and after car was painted it would not start? It always started hard but always started, they are telling me they pulled the plugs and are really wet, they cleaned them up and same thing no start with wet plugs again, I’m going to try changing the plugs tomorrow and have read cleaning the maf with maf cleaner might help as well, is there anything else I can try? I need to get it running to get it on the trailer. Help
Old Mar 22, 2012 | 03:17 PM
dougbfresh's Avatar
dougbfresh
Getting SPARK?
Old Mar 22, 2012 | 05:59 PM
Jeff in Den's Avatar
Jeff in Den
Originally Posted by dougbfresh
Getting SPARK?
Wet plugs could definitely mean no spark. Were they all wet? I would doubt 8 plugs went bad, yet I'd doubt 8 wires went bad all at once either.....unless they are getting burnt by the exhaust manifold...
I would think it would be easier to change the wires first.
Old Mar 22, 2012 | 06:52 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Wet with water, coolant or fuel? If its water, how much do you wish to bet that they were out driving it somewhere?
Old Mar 22, 2012 | 07:37 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
READ AND POST THE DTCs!!!
READING YOUR Engine Diagnostic Codes (DTCs)
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open etc…)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes)
If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, C or ;H. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present;
press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET
To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
Here is very good site of DTC definitions:
http://www.gearchatter.com
Make sure to include the H or C suffix!!
To car wont start .....flooding
