Water wetter
Old Mar 22, 2012 | 09:12 PM
rttmike's Avatar
rttmike
Default Water wetter
Has anybody ever used this with dexx cool in a C5? Curious if it woks well.
Old Mar 22, 2012 | 09:19 PM
hotwheels57's Avatar
hotwheels57
It's a water surfactant. Basically, it means it makes the water slippery breaking surface tension, allowing coolant to move easier and air to move out of the motor.
It'll work fine with your DEXCOOL. Don't expect major temperature reductions. It will stabilize temperatures. I've used it for years in AZ summer temperatures.
Old Mar 22, 2012 | 11:39 PM
ZedO6's Avatar
ZedO6
Works much better with H2O and no coolant. As much as 15 F difference. With that said, best for track use or if you like frequent coolant changes. Leave it in and forget it and you'll get some nice reminders down the road.
Old Mar 23, 2012 | 12:51 AM
Marine One's Avatar
Marine One
Used it years ago in a 5.0 liter Mustang GT that ran hot in traffic in summer. It made no discernible difference. Ended up getting the radiator rodded and that fixed it.
Old Mar 23, 2012 | 07:52 AM
AU N EGL's Avatar
AU N EGL
two bottles works better.
No real need to 50/50 Dex mix. but a 90/10 water/dex then add 2 bottles of WW
Old Mar 23, 2012 | 10:35 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
It works best with plain water.
Old Mar 24, 2012 | 12:25 AM
RogerT's Avatar
RogerT
Default Double Dose!
It is recommended you put two bottles in a Corvette.
One place you can read this recommendation is in the Mid America Motorworks catalog.
I used two bottles when I installed a 160 degrees. 198 degrees down to 178 degrees.
Roger T : )
To Water wetter
