Alternator bracket removal/replacement
Old Apr 5, 2012 | 08:15 PM
Speed Trap's Avatar
Speed Trap
Default Alternator bracket removal/replacement
Can anyone give instructions on how to remove/replace the alternator bracket on the C5's? Are there any special tools required and are there any other parts, other than the alternator itself, that needs to be removed in order to get the bracket off?
Old Apr 5, 2012 | 09:27 PM
Last C5's Avatar
Last C5
The power steering pressure and return lines will have to be removed as the ps pump is bolted to the bracket and will have to removed with it.
Old Apr 5, 2012 | 09:38 PM
Zeus-of-Boost's Avatar
Zeus-of-Boost
yep, why are you removing it?
Old Apr 5, 2012 | 11:50 PM
Speed Trap's Avatar
Speed Trap
Was thinking of replacing it with a chrome or polished one. Sounds like I'm going to get power steering fluid on everything to do the swap. So there is not enough slack in the lines to do it without disconnecting the lines from the power steering pump?
Old Apr 6, 2012 | 12:43 AM
Last C5's Avatar
Last C5
The ps pressure line is a ridgid line - there is no slack at all.
Old Apr 6, 2012 | 07:52 AM
vettenuts's Avatar
vettenuts
If the bracket is out you may be able to get the pump off the bracket, otherwise you need the PS pulley tool or the pulley will break. I seem to remember you might be able to sneak it off with an open end wrench once the bracket and pump are out of the car. Look through the driver's side wheel well, the hose connections are right there.
Old Apr 6, 2012 | 09:45 AM
Speed Trap's Avatar
Speed Trap
Thanks, I'll check it out.
To Alternator bracket removal/replacement
