Amsoil
Old May 19, 2002 | 08:38 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Amsoil
Where can I get some fluids for tranny and rear end??? And which ones do I need..Thanks
Old May 19, 2002 | 09:37 AM
pewter99's Avatar
pewter99
Default Re: Amsoil (pewter99)
:confused:
Old May 19, 2002 | 09:43 AM
vettenuts's Avatar
vettenuts
You can order from their web site or contact them for a local distributor.
You should use the Series 2000 75W-90 for the rear differential. For the engine, although their latest Series 2000 has very good specifications it is a 0W-30, the manual states 5W-30 so I had to order a case of it. I was nervous about using something not specified in the owners manual. I think the 0W-30 would be fine and the 100 degree C viscosity is still superior to Mobil-1 10W-30, you never know with a dealer what they are going to say about warranty so I didn't want to chance it.
Old May 19, 2002 | 12:23 PM
Snake Slayer's Avatar
Snake Slayer
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Amsoil (vettenuts)
Rob, I sent you an IM
Cecil
Old May 19, 2002 | 12:52 PM
Viprklr's Avatar
Viprklr
Default Re: Amsoil (Snake Slayer)
I too am using the AMSOIL Series 2000 0W-30 oil. However, using Redline fluids in tranny and diff. :cheers:
Old May 19, 2002 | 01:40 PM
Finish line's Avatar
Finish line
Default Re: Amsoil (Viprklr)
Going to change to amsoil in about a week. I am amazed at the difference some of my friends have seen in their vettes. :smash: :smash:
Old May 19, 2002 | 07:45 PM
carpe dm's Avatar
carpe dm
Get all the info and order from http://www.amsoil.com A bit more expensive, but worth it. Engine runs cooler and gas mileage improved too. :jester
Old May 20, 2002 | 09:50 AM
VetteVert's Avatar
VetteVert
Default Re: Amsoil (carpe dm)
If you are going to order > $100 worth of stuff, it pays to do their "preferred member" program (basically you are buying down the markup rate). I'm buying a bunch today, stocking up on engine oil, gear/tranny oil, and filters for my cars. Saves on shipping as well.
VV
Old May 20, 2002 | 02:15 PM
TAL's Avatar
TAL
quote;
"I was nervous about using something not specified in the owners manual. I think the 0W-30 would be fine and the 100 degree C viscosity is still superior to Mobil-1 10W-30, you never know with a dealer what they are going to say about warranty so I didn't want to chance it."
Just remember a 0W-30 does fall into the 5W-30 catagory. Matter of fact it exceeds it.
Dealer will never know whether you have a 0W or 5W weight oil. OK maybe if they do oil analysis....but that's going a little far for a dealer.
To Amsoil
