Need help picking out a cam??
Old Apr 10, 2012 | 12:32 PM
skeeters65's Avatar
skeeters65
Default Need help picking out a cam??
I know there are a million choices and a million different reasons for each cam..
My question is how did you guys decide what cam to put in your car?
There isnt a whole lot of cammed LSX motors around my area to listen to or drive..
I did have a 69 Camaro with an LS1 that I put a Texas Speed Magic Stick 3 in. I liked the cam but I think I want something that makes power a little lower in the RPM range this time.
I did really like how choppy it was though.
Any way how to go about picking a cam?
Old Apr 10, 2012 | 01:11 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
this is who I used http://guerragroup.com/camshaft_help.htm
Old Apr 10, 2012 | 01:12 PM
feeder82's Avatar
feeder82
Ask one of the vendors, Vengence, Speed inc, Texas Speed,ECS, tell what you want to do go from there
Old Apr 10, 2012 | 01:18 PM
AU N EGL's Avatar
AU N EGL
Smaller cams can make power much earlier in the power band
MS2 or a 224/230 or a 228/232
LSA of 112 has a nice chop to it.
Old Apr 10, 2012 | 01:58 PM
RonSSNova's Avatar
RonSSNova
Originally Posted by printmanjackson
You get a custom cam tailored to your needs from Comp (all these others are also ground by Comp) for pennies more than an off the shelf grind.
Ron
Old Apr 10, 2012 | 02:58 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Getting a LOWER LSA will make it choppier--A 112 is mostly used for that--For more power and more importantly Torque- a lower duration in the mid 220's wil keep the peak HP & TQ below 6000--- and lower down in the 3000 range -- With a 6 speed you can get away with a bigger cam than an A4 with a STOCK converter--Old school method is to do all your homwork and research 1st -pick a cam--then go one size bigger !!! If smog is not an issue and If it were my car I would still get something in the low .230's--Especially with a 6 speed--- A .220 cam will limit the HP gain to about 25-30 RWHP but a .230 ish cam could result in as much as 35-50 RWHP gain ---You already have plenty of head with your 243's and have a LS6 intake and the bigger cam will benefit greatly--You may just have to adjust your driving style a bit---------
Old Apr 10, 2012 | 08:44 PM
Paul 75 L82's Avatar
Paul 75 L82
Texas Speed 228R, makes great HP & Torque.
Old Apr 10, 2012 | 09:13 PM
skeeters65's Avatar
skeeters65
Looking for a little more chop than that..
Old Apr 10, 2012 | 09:56 PM
motogib1's Avatar
motogib1
Do your homework and determine what your goal is. otherwise you may end up replacing the replacement cam which is what I did. Went from a TSP 224R to a TSP Torquer V2 as my goal was low 11s. Just depends on what you want.
Old Apr 13, 2012 | 12:41 PM
tblu92's Avatar
tblu92
Even with a cammed Z06 low 11's is optimistic---Traction will become an issue--as well as finding the perfect launch RPM--Too high and you will spin the tires--too low and it will bog--takes lots of track time to sort it out--Wheel hop is also a problem on Z's and a killer of drive axles--It really shocks the drivetrain--An A4 with a stall is more draivetrain friendly--
To Need help picking out a cam??
