5th gear grind
Old Apr 23, 2012 | 09:34 AM
turbolvr321's Avatar
turbolvr321
Default 5th gear grind
Ok. I got the infamous 5th gear grind. Reverse works fine, 5th gear works when stopped. After doing research, figured on reverse lock out solenoid.
Replaced said lock out solenoid (that's a fun story in itself).
5th gear still grinds, same conditions as before.
Any ideas?
Old Apr 23, 2012 | 02:03 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Any ideas?
I would guess broken plastic fork pads.
__________________
Old Apr 23, 2012 | 03:18 PM
turbolvr321
It doesnt go into reverse after the car is off, so I am led to believe that means the solenoid is in good shape, correct? Car only has 45k miles, and as far as I know was quite literally a weekend cruiser.
To 5th gear grind
