ticking/knock noise
Hope this helps.
Tom
Do some checking before you begin repairs.
good luck
Noises/sounds can be subjective though, so it's always possible something could be going south (rocker arm) or just LS roller lifter, noisy injectors (or a combination).
The oil sat around for a while, and I asked the manager what he was going to do with it, as I was getting ready to change the oil in the C-5 and put the car back on the road for the summer. He dug through the computer, and found out that we got the oil by mistake, but there was no easy way to return it. Somehow or other, he found a "store cost" for the oil, and I bought it for that reduced amount.
I ran the oil all last summer, and although there's no scientific evidence to prove anything, the car seemed quiter. I put Mobil1 in the car this spring, and the "occasional lifter clatter" is back....
The EPA said that our cat converters were more important, and we had roller lifters anyway, so the zinc wasn't really necessary.......
As I previously mentioned, I work part time at the auto parts store. A few months back, some old gentlemen came into the store, and wanted to "return" 12 quarts of 10-40 Valvoline oil, said he no longer needed it. Even though he still had the sales slip, the oil was OLD, about 2-3 label designs ago, the copyright on the back read 1991.
Obviously, we explained to him that we couldn't take back the oil, because we had no way to resell it, but we said we could recycle it for him. He understood, and left the oil with us. Naturally, we didn't dump it, but I took 5 quarts, and the other counterman took 7, as he has an older car too.
I put the oil in my Z-28 a few weeks ago, when I put it back on the road. I know that 10-40 is heavier than the 5W-30 that GM calls for, but I'm sure the real reason the car sounds noticibly quieter is due to the higher zinc content in this "old" oil, as I've had the "low zinc" 10-40 in the car in the past, but still heard a little clatter from the valvetrain.....
My 2004 daily driver, 161k miles, JUST RECENTLY, maybe a couple months ago, started the same symptoms - tick, tick, tick, when starting the engine after a week in the garage. Lasted maybe 5-10 seconds the first time it did it. Then not at all for a couple weeks, then it did it again after sitting, and as the days went by it happened more often, and lasted a bit longer.
This morning, it made the same audible tick, tick, tick for 3-4 minutes, including while driving out of my neighborhood. I suppose it is the hydraulic lifter bleeding out the oil, and then not refilling adequately, and the problem seems to be getting worse.
I use Mobile 1 oil and filters, always have. A couple of weeks ago, I used a single application of a commercial oil additive/solvent, ran the engine 10 minutes and then changed oil - hasn't seemed to help. The pressure was good (60 psi on the panel gauge this morning).
So my questions: 1) Am I damaging my camshaft or valvestem by having slap/play in the valve train for seconds/minutes? 2) manual mentions oil filter by-pass valve - should I replace this? 3) Manual also mentions replace lifter as required - doesn't look too bad, but I suspect this might be a "big" job. Is it?
Thanks in advance for any advice
If this is the case, I may be looking at switching to Amsoil's "high zinc content" syn oil.
I work part time at Advance Auto Parts, and I was putting some oil on the rack yesterday. While doing so, I noticed that Mobil1 has a 15-50 syn oil, and the package is marked with the verbage "has increased anti-wear ingredients", or something like that.
Just an FYI.
Just an FYI.
. Took it to a locale shop and as i feared was told it was a lifter going bad.
