ticking/knock noise
Bottom line, I'm draining that junk oil (mobile 1) and going with something with a higher zinc content.
I am dealing with a new problem (can't shift into any gear with the engine turning over, but can when shut down) and so I came to the forum for ideas. The lessons I learned during work I have done (myself, for the most part) include:
Coolant was definitely getting into the oil via porous block. GM "Cooling System Seal Tabs (part # 3634621)" are a must. Confidence level 99%
Oil changes probably should be more frequent than mfg recommendation, or DIC output. Confidence level 90%
ZIP Corvette transmission that I installed (Mine suffered what I would describe as a catastrophic failure involving much damage to the internals) was junk (loud whine in 3rd), and had to be re-installed (at Zip's expense). Never has been the same (audible whining in 2nd and 4th), and I could have purchased a NEW dealer transmission (Tremec) for almost exactly the same price. Additionally, the 'core charge' was only partially paid - standard practice, according to ZIP manager. Confidence level 100%
Although I am still driving the 2004 (now with 205,000 miles) - I am leaning very heavily towards a C7, which I hope to purchase and take delivery of at Bowling Green
