V1 rearview mirror mount
Old May 21, 2002 | 01:55 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Default V1 rearview mirror mount
Anyone have their V1 mounted using the bracket that hangs from the rear view mirror? Pics of install, like it or not?
Old May 21, 2002 | 02:08 PM
427 Predator's Avatar
0427 Predator
Supporting Tuner
Default Re: V1 rearview mirror mount (2k2C5)
I saw one in a guy's '01 Z06 and really liked it but it was in it when he bought the car so he didn't know where to get one. Very discrete and the unit came on and off easily.
Do you?
Old May 21, 2002 | 02:13 PM
jefffxdwg's Avatar
jefffxdwg
Default Re: V1 rearview mirror mount (RacerX413)
I have one and love it. Very discrete, cant see any wires.
Old May 21, 2002 | 03:01 PM
pip's Avatar
pip
Careful, mirror mount does not mount to all C5 mirrors. I use the visor mount an think that the higher position is actually more discreet.
Old May 21, 2002 | 03:06 PM
Patman36's Avatar
Patman36
Default Re: V1 rearview mirror mount (pip)
So do they make a mount that is compatible with the '02's and electrochromic mirrors?
Patrick :cheers:
Old May 21, 2002 | 03:10 PM
wwashing's Avatar
wwashing
The visor mount greatly reduces (or totally kills) the lazer detection and reduces the other bands as well do to the high tint area.
Old May 21, 2002 | 03:17 PM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Default Re: V1 rearview mirror mount (wwashing)
http://www.greatlakestrophies.com makes one that I use but I heard it only works for 2000 or older models so I guess that doesn't help you too much.
Old May 21, 2002 | 06:11 PM
RWhite's Avatar
RWhite
If you make your own visor mount by bending a piece of thin stock metal (a 1"X6"X50 mil. thick scrap from the Depot or Lowes), you can clear the tint. I did that and used the screw that holds the passenger visor as a mounting point.
Old May 21, 2002 | 06:36 PM
0427 Predator
Supporting Tuner
Default Re: V1 rearview mirror mount (RWhite)
Roger -
Thanks, sounds like a good idea. It will be a whole lot less expensive than buying one anyway.
Did you have any problem regarding the rear view mirror. I have an '02 as well (Z06) and I have seen comments that the mirror configuration changed somewhat in either '00 or '01.
Thanks again. :cheers:
Old May 21, 2002 | 11:41 PM
RWhite's Avatar
RWhite
No interference. I just bent the piece of metal like a flat "s" or "z" so it would clear the tint and be far enough forward to not interfere with the passenger visor when it was down. I painted it black to match the surroundings. It stays put because one of the holes already in the metal stock had a hole in it that lined up with the little plastic tit on the visor hold down clamp.
To V1 rearview mirror mount
