Car will not crank over??????????
Old May 11, 2012 | 10:46 PM
helga203's Avatar
helga203
Default Car will not crank over??????????
Parked car came back to start heard all the usual fuel pump and releys clicking then tryed to start and nothing no cranking at all. No codes. Checked all fuses and relays seem fine. Ignition switch is good. When i put to start position i get 12 volts to the yellow wire. I think it might be serurity system. How can i check this is. Is there a relay? Tryed to disconnect battery still nothing. Tryed back up key ,same no cranking. Any help would be great.
1999 C5 mn6 coupe
Old May 12, 2012 | 06:52 AM
helga203's Avatar
helga203
Originally Posted by 8VETTE7
Pull the codes and post them. Include the H or C or HC that follow the codes:
http://www.c5forum.com/ayc/dtcdic.php
No codes. I cleared codes yesterday and tryed to start car right now and nothing. Checked codes nothing again. My pull key wait 10 sec comes on which hasen't done that since i put the bypass in and removed that nipple that holds the steering wheel from turing you helped me with that a few moons ago.
O.K. Checked both key resistors and their 522 omhs which is correct tryed the relearn didn't help.
Is there anyway to check if ingition switch is bad. When i turn the key i get 522omhs at the two wire that gos to bcm. So seems like ingition switcg is ok.
Old May 12, 2012 | 07:59 AM
helga203's Avatar
helga203
I found old theard that i'm not getting 12v to theft relay is there a way to bypass relay or jump without damaging anything esle????
Old May 12, 2012 | 08:22 AM
helga203's Avatar
helga203
Default "Got it
Found the problem it was a mini fuse to ingition sw. Thanks for helping
Old May 12, 2012 | 10:51 AM
lucky131969's Avatar
lucky131969
While I'm glad you figured out the problem, that is a very unusual fuse to blow. You've got a intermittent short between the minifuse 14, and the TDR.
To Car will not crank over??????????
