Headlights goin' dim.
Old May 14, 2012 | 01:23 AM
FruiTay's Avatar
FruiTay
Default Headlights goin' dim.
I just got a BRIGHT red 01' Z06 with 36,000 miles BUT I noticed in the mornings on the way to work my headlights will kinda flicker dim at random Any ideas?
Thaaaaaaank yooooooou!
Old May 14, 2012 | 07:40 AM
andrec10's Avatar
andrec10
Loose Ground?
Old May 14, 2012 | 09:39 AM
65GGvert's Avatar
65GGvert
When you say random, do you mean when you're not touching the brake or power window switches? Either of those can make the headlights dim momentarily, as can a loose connection on the battery cables or at the red wire on the starter solenoid coming from the battery that ties the alternator and battery together.
Old May 14, 2012 | 01:25 PM
FruiTay's Avatar
FruiTay
It's just when I'm driving, not braking or using any switches. I'll see if anything is loose with that wire. Thanks for your time my man! I appreciate it.
Old May 15, 2012 | 09:27 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I noticed on my '99 when I would leave from work every night (2nd shift), that about 10 miles down the freeway, my headlights would dim each and every night about the same time. I finally figured out that it was the alternator, commanded by the PCM, switching from a high rate charge to a lower rate charge, from the cold start-up and the need to replace the battery power consumed in the start-up.
Old May 15, 2012 | 09:47 AM
Corvette_Ed's Avatar
Corvette_Ed
Aftermarket stereo's and amplifiers can cause this to happen sometimes too. An old '70 Nova I used to own had headlights that would beat to the music....
To Headlights goin' dim.
