fluids change questions
Old May 14, 2012 | 09:29 PM
cadman64's Avatar
cadman64
Default fluids change questions
I have a 98 mn6 that I have owned for almost four years. I am looking to change "all" the fluids. I have the oil changed once every year so I know how much oil to buy. The owners manual tells me what to use and that is what I want to stay with. My question is how much? Can I get these fluids at the local auto parts store or do I / should I get them at the dealership?
Old May 15, 2012 | 01:42 PM
DeeGee's Avatar
DeeGee
It doesn't post well but if you can work it out, all the info is here:
Document ID# 760071
2002 Chevrolet Corvette
Capacities - Approximate Fluid
Fluid Capacities
Application
Specification
Metric
English
Important
All capacities are approximate. When adding, be sure to fill to the appropriate level, as recommended in this manual.
Air Conditioning Refrigerant R134a
0.79 kg
1.75 lbs
Cooling System
11.9 L
12.6 qts
Engine Oil with Filter
6.1 L
6.5 qts
Fuel Tank
68.0 L
18.0 gals
Rear Axle Differential
Lubricant
1.6 L
1.69 qts
Limited-Slip Additive
118 ml
4.0 ounces
Transmission Fluid
Drain and Fill Automatic Transmission
4.7 L
5.0 qts
Overhaul Automatic Transmission
10.2 L
10.8 qts
Overhaul Manual Transmission
3.8 L
4.1 qts
Power Steering Approximate
0.81 L
1.7 pts
Wheel Nut Torque
140 N·m
100 lb ft
Engine Specifications
Engine
VIN Code
Transmission
Spark Plug Gap
Firing Order
LS1 V8
G
Automatic
1.0 mm (0.040 in)
1-8-7-2-6-5-4-3
LS1 V8
G
Manual
1.0 mm (0.040 in)
1-8-7-2-6-5-4-3
LS6 V8
S
Manual
1.0 mm (0.040 in)
1-8-7-2-6-5-4-3
Engine Data
Engine
Horsepower
Torque
Displacement
Compression Ratio
LS1 Automatic Transmission
350 @ 5200 RPM
360 lb ft @ 4000 RPM
5.7 L
10.1:1
LS1 Manual Transmission
350 @ 5200 RPM
375 lb ft @ 4400 RPM
5.7 L
10.1:1
LS6
405 @ 6000 RPM
400 lb ft @ 4800 RPM
5.7 L
10.5:1
Document ID# 760071
Old May 15, 2012 | 01:52 PM
dbaker's Avatar
dbaker
I highly recommend Amsoil products...I run it in all my 4 rods.
Look up what you need here...
http://www.amsoil.com/MyGarage/VehicleLookup.aspx
See forum member SubDriver....he can take care of your Amsoil needs.
\db2
carolina
To fluids change questions
