TI exhaust
Old May 19, 2012 | 11:24 PM
DICKIE GOOBER's Avatar
DICKIE GOOBER
Cruising
good luck finding someone who knows how to weld Ti... ;-]
Old May 19, 2012 | 11:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Any welder can weld Ti.. The special technique is to provide the required shield gas over the weld.
To weld that pipe, you would have to purge and fill the pipe with ARGON and use a special oversize shield cup on the welding torch to keep the ARGON shield gas over the weld.
BC
Old May 20, 2012 | 01:13 AM
m6 c5's Avatar
m6 c5
Originally Posted by Bill Curlee
OEM Stock C5 is really ALUMINUM COATED STEEL. The ZO6 system is high quality Titanium and the set weighs 24 lbs less than the stock C5 mufflers.
Bill
Yea at first I thought it was stainless because my factory exhaust did not really have any rust even with over 100k on it. It had some at the weld points and on the 3 in section of it but other than that there was none.
