Clutch Bleeder-Learned something new
Old May 17, 2012 | 06:33 PM
k24556's Avatar
k24556
Default Clutch Bleeder-Learned something new
I was at the NCM bash last month sitting at Gate D doing parking duty, shootin' the breeze with a really great guy that retired from the assembly plant (he built Corvettes for 41 years)
We were talking about a recent remote clutch bleed install I did and I asked him who the rocket scientist engineer was that put the hydralulic clutch bleeder in a place where only Stretch Armstrong could reach.
His reply was that it was not put there for my convenience, but, because it is really an automatic air bleeder, which bleeds only the air during the assembly of the car and is the high point vent for the clutch slave cylinder.. Makes sense why it is where it is. While it can be used as a bleed screw, that is not the first purpose for it.
You are probably thinking like me, how long will it work bleeding air with the fluid getting dark and cruddy so fast.
Bottom line, the remote bleeder is a good mod.
Old May 17, 2012 | 07:43 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I love my remote bleeder !
Toque
Old May 18, 2012 | 02:19 PM
cdkcorvette7's Avatar
cdkcorvette7
Toque
Old May 18, 2012 | 11:13 PM
chevynovaguy72's Avatar
chevynovaguy72
Every clutch I install I put one in!!!
Old May 19, 2012 | 09:37 AM
sothpaw2's Avatar
sothpaw2
Have any of your customers ever had issues? How does the line attach to the hydraulic system...welded in or tapped/threaded w/ a crush washer?
Old May 19, 2012 | 09:47 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its just a LONG bradded SS brake line type hose. It has a fitting that threads into the hole where the factory bleed fitting is. It comes with a copper washer. The other end has a regular brake bleed fitting that you crack open to bleed out the air and old fluid.
BC
Old May 19, 2012 | 10:02 AM
chevynovaguy72
Not all use the copper washer. The Katech one and a few others use the same fitting style as the factory blessed fitting does with the tapered seat. But yes it's a long SS flex line that you mount up by the clutch or brake master cylinder reservoir. Makes it VERY simple to bleed or flush the clutch hydraulic system! Usually they only run ~100-120 bucks.
Old May 19, 2012 | 10:08 AM
chevynovaguy72
Not blessed fitting but style fitting. Damn auto correct. Oh and i haven't had one fail. Only seen one fail due to incorrect install - Steel zipties will rub through stainless!!
Old May 19, 2012 | 11:55 AM
sothpaw2's Avatar
sothpaw2
To What and where do you secure the braded lines with? Funny you mention that as my installer has always said "it doesn't matter if anything rubs these since they're stainless; they'll rub through any other material". Not a position I've ever been willing to take.
Any brands of bleeder kit to avoid? What are the better/more reliable ones?
Old May 19, 2012 | 12:19 PM
chevynovaguy72
I've only used the Tick and Katech brand ones. Both of great quality with 0 install issues. They are pretty simple anyways. But both I've used in over 20 cars both C5 and 6.
Old May 19, 2012 | 06:59 PM
Edmond's Avatar
Edmond
I used a metal zip tie to secure mine to the master cylinder area, can't remember exactly where as of this moment.
I do not think there is that big of a difference in the bleeder, it's not used that often unless you are tracking your car.
I bought mine from East Coast Performance.
To Clutch Bleeder-Learned something new
