Mobil 1 (a synthetic oil) is what most go with, and is what your owner's manual recommends. The weight depends on where you live, and since you live in PA you should stick with the 5/30 weight because of the cold winters. I use 10/30 because the temp here in TX doesn't drop below 20 degrees in the winter except for the once-every-hundred-years cold snap. I need the higher weight to deal with the heat here.
If you're burning through that much oil you should find out where it's going. An engine with that few miles should not be burning oil that fast, if at all. Mine has 70k miles on it now, and after changing out my valve cover gaskets & grommets I'm not losing a drop.
Not only does 10W-30 NOT protect better under hot weather conditions when compared to 5W-30, but the 10W-30 oil is more viscous at first startup, which is when most engine wear occurs.
I spoke to a Mobil 1 applications specialist and he told me that he lives in Texas AND uses Mobil 1 0W-40 for his truck. That protects better during high ambient temperature conditions and at startup.
That doesn't make sense to me. How would a thinner oil protect against high heat better? It seems to me the heat thins the oil enough by itself without going with thinner oil. I went with the 10/30 by recommendation from the owner's manual for areas that don't drop below 20 degrees.
My engine on my 2000 vert seem to be consuming about a quart of oil every 750 to 1000 miles. Engine only has 18,000 miles on it.
Any suggestion for a best type oil and weight to use.
I did a search but didn't find a specific answer.
Thank you
That is very high oil consumption. Something is broke. My 03 with 88K miles uses none oil and I change when the DIC says 0% which is about 7500 miles with Mobil-1 0W30.
A quart every 1000 miles isn't "normal" either. I've never had an engine that burns that much oil. Most C5s will burn a quart every 3000~4000 miles if driven hard once and awhile.
I am sure he meant to say 1qt every 1000* miles. The 2000 year engines seem to have this problem. Search it on here, you will find more info.
It's the 01's that are infamous for their oil consumption...
OP; just use any oil that meets or exceed GM Spec as it says in your owners manual. Factory fill is mobile 1.
The bigger issue is the consumption itself; that much consumption is not normal. My 01 doesn't even eat that much oil and it burns through a little more than I'd like. You need to figure out where that oil is going. If it's a leak and it gets worse you could damage your engine.
Thank you
I had the same issue with my 2001 coupe. Read GM's TSB (technical service bulletin) on the subject, it will help you understand what is taking place. Your driving style may be contributing to the excess consumption. Finally, switch to Mobil 1's 5w-30 high milage formulation, it contains an additive which lowers volatility resulting in reduced oil consumption. These two changes lowered the oil consumtion on my coupe to negligible levels.
0W-40, really isn't a "thinner" oil. The chemical make up of it renders it a zero weight cold, but a 40 weight when it's hot, therefore it's actually a "thicker" oil. Isn't modern chemistry wonderful?
Back on the topic, my '01 uses about a quart in 2000 miles, which I consider a bit much. However, it's a stick shift car, and downshifting for turns and street corners creates a bit of vacuum in the cylinders, which I'm assuming, is causing the oil loss...
1 qt every 1000 miles is NORMAL for most cars. Doubt you could even get any dealer to even listen to you for that kind of consumption.
No, it's not. "Most cars" should lose little to no oil, leaning more toward no oil loss. The only time any car I've ever owned had oil loss was when a gasket was leaking or the piston rings were worn. My 2000 hasn't lost a drop since I changed the leaky valve cover gaskets/grommets. If you're losing that much oil you have a serious problem.
Mine is also a manual and I'm not losing any oil. If it were my car losing that much oil I'd be looking for the reason.
As far as oil type for my car, no offense, but I'll stick with the manufacturer's recommendation for my area's temperature range. What works for a pickup truck isn't necessarily the best for a high performance Corvette engine.
Looks like the 5W-30 High Mileage forumula doesn't meet the General Motors 4718M spec - at least it's not shown as such on Mobil 1's website. Doubt it would harm if used.
OP - nobody mentioned it, but you should check the PCV system to make sure it's working properly. Could be the oil is being sucked into the intake manifold if the PCV valve is stuck wide open for instance, or if someone messed with the PCV hoses and got them reversed somehow.
