Ls6 throotle body vs ls1
Old May 21, 2012 | 09:38 AM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
Default Ls6 throotle body vs ls1
Can you pick up any performance value by putting a ls6 one on a ls1 engine. Thanks
Old May 21, 2012 | 09:46 AM
chaase's Avatar
chaase
St. Jude Donor '12
I didn't think there was a difference between the two.
Old May 21, 2012 | 10:57 AM
ALLEGRO's Avatar
ALLEGRO
I thought the CFM was the same for both. Not sure though ??!!??
Old May 21, 2012 | 11:13 AM
SDPC's Avatar
0SDPC
Former Vendor
Same throttle body.
Old May 21, 2012 | 11:56 AM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Let me rephrase the question for you.......
Will ANY throttle body improve performance over the stock LS1?
Old May 21, 2012 | 12:52 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
A ported LS1/6 TB will improve throttle response some and maybe add a few HP (nothing to write home about)
The only TB that will improve performance is an LS2 but it wont fit a non modified LS1/6 manifold.
TPSI can morph on a LS2 flange to your LS1/6 manifold. You need mods and a tune to take advantage of the added air flow. It wont do a non modded LS1/6 much good.
Bill
Old May 21, 2012 | 12:54 PM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
I know their are some that will. I just have the question on the ls6 motor z06. They seem from what people THEY are the same. I thoght they were over 80mm.
Old May 21, 2012 | 01:52 PM
PhilsFRC's Avatar
PhilsFRC
Same TB for both.
Old May 21, 2012 | 02:24 PM
cdkcorvette7's Avatar
cdkcorvette7
Originally Posted by PhilsFRC
Same TB for both.
Old May 21, 2012 | 03:00 PM
baxsom's Avatar
baxsom
they are not the same, the LS6 one has a sticker on it
Old May 21, 2012 | 04:23 PM
BigGun's Avatar
BigGun
It is like the wings the ricers use...probably good for 25-30 hp.
Old May 21, 2012 | 06:02 PM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
Great one the ls6 does have a emblem on the throtle body 2004 z06.
Old May 21, 2012 | 08:16 PM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
Thanks for all the great info: I know have two with 20k/z06/// year 04 with emblems on them. Maybe get rid of one// philly joe//
Old May 22, 2012 | 03:38 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
the peel on sticker was on the base car also, "LS1" in red letters
Cam/headers is the only gain you will notice if on a budget
Old May 26, 2012 | 08:22 AM
bontrager's Avatar
bontrager
My experience wit ha ported throttle body has been terrible.
Just changed yesterday to a BBK 80mm throttle body.
So far I am very satisfied, no error codes or check engine light. Much smoother idle.
However don't expect huge gains with ANY throttle body unless you are changing the intake manifold also. Even at that you may be looking at a small HP improvement.
Bottom line, I don't think the money spent on a new intake and throttle body is worth it; maybe if you are doing all of the work yourself you can consider with the addition of a CAI system and headers.
Save your money for a super charger!
Old May 26, 2012 | 09:33 AM
AU N EGL's Avatar
AU N EGL
Just a tb change is not enough to do much.
But part of a whole package:
CAI
pp tb
Lts,
high flow cats
low restrictive mufflers
AND DYNO TUNE, yes there will be a differnce
Old May 26, 2012 | 11:30 PM
WildVettes's Avatar
0WildVettes
Former Vendor
St. Jude Donor '12
I haven't had a customer yet that wasn't happy with their BBK TB. I just installed one of their TBs on my suburban and was very satisfied.
Our cars tend to get picky with too much air, once I went to a 90mm on my Z it went into limp mode and needed to be tuned. I think that is why BBK chose to limit the size to 80mm on the Vette.
To Ls6 throotle body vs ls1
