Replacing the lifters
Old May 21, 2012 | 12:48 PM
RedC5CO's Avatar
RedC5CO
Default Replacing the lifters
Hi All,
I've got a bad lifter. I've pulled the head off and all of the lifters came out easily, except for the bad one. It comes out about a 1/4 inch and gets stuck. I was going to remove the valve valley cover to see if I can see the bottom of the lifter. How do I disconnect the knock sensor connectors? Any other thoughts on how I can get this lifter out?
Tom - 98 injured coupe
Old May 21, 2012 | 01:21 PM
RonSSNova's Avatar
RonSSNova
It is no doubt mangled on the bottom side. Which means it would have to come out from the cam side. That means remove the engine pretty much.
If it is pulled through the lifter bore, it will damage the bore.
Ron
Old May 21, 2012 | 02:01 PM
warren s's Avatar
warren s
When you remove the valley cover, you can pop off the black plugs and unplug the connector. You can unscrew the knock sensors with a ratchet.
If the bottom end of the lifter is bad it most likely also took the cam lobe with it.
You can remove the cam with the engine in the car and "possibly" get the lifter out of the bottom - but its a gamble that it didnt scrape up the lifter bore. I would do that first before pulling the engine.
Old May 21, 2012 | 02:09 PM
RedC5CO's Avatar
RedC5CO
Thanks guys, that's really bad news.
Old May 22, 2012 | 04:53 AM
vettenuts's Avatar
vettenuts
Valley cover removal will let you see only a couple of lifters. Not sure which one it is but you may not be able to see it with the cover off.
Old May 22, 2012 | 07:57 AM
crainholio's Avatar
crainholio
I was able to help a friend remove a damaged lifter similar to yours by removing the cam (lobe was trashed also) and carefully dropping the lifter out the bottom of the bore. We used a pair of magnet-on-a-stick on either side of the lifter to help catch it...don't want it dropping into the oil pan.
Old May 22, 2012 | 08:02 AM
kmetros's Avatar
kmetros
I agree, especially if you remove the other head, lifter trays and lifters. That will essentially double your access space. Removing the cam is a must but it's a lot easier than removing the whole engine that's for sure.
Old May 22, 2012 | 08:39 AM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
Ron
Been there done that, he doesn't have to remove the engine, but he does have to drop the oil pan.
Old May 22, 2012 | 04:07 PM
RedC5CO's Avatar
RedC5CO
Thanks everyone! I'm going to start removing the other head and camshaft this weekend.Hopefully I'll get the lifter out the bottom. I'm a little encouraged by the fact that the lifter moves freely to a point, about 3/8 inch and it rotates smoothly. It feels like a needle bearing popped out the side and is blocking it from coming up. I tried using a mirror like the dentists use, on the end of a stick. My eyes are too old to tell anything useful, other than the lifter stops coming out when the bottom is even with the journal.
To Replacing the lifters
